| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
02-16-2003, 03:57 PM
TX
Cobra Make, Engine: FFR3340-302 300Horse 3.55 gears
295/50-15 on 7"wide wheels????
I tried to get 275/50 radial T/A's but they couldn't find them in any of there stores.Has BFG stopped making this size? The next size up is 295/50. I know they are a little wide for the 7" wide wheels but has anyone had any luck with them.
Lovin life in Austin! Finally finished !Titanium silver and black stripes.
02-16-2003, 04:07 PM
FL
Hi Mike,
Tire Rack has a listing for seven different models in the 295/50-15 size, made in six different brand names. They list two BFGs in the 275/50-15 size.
What worries me ( and should worry you! ) is that not only are they an "S" rated tire - read "lowest speed rating" - but the narrowest rim BFG recommends is 8" for the 295s, and 7-1/2" for the 275s.
Where I come from, putting these onto a 7" rim might constitute some sort of death wish...
You might be better off with some 245 or 255/60-15s at least for the rims you have. Still not a good high speed tire, though.
Tom
02-16-2003, 05:12 PM
Estimated top speed for a 302 and 3:55 gears is about 110-115, at say, 5500 rpm? You can calculate it, I didn't bother, but I bet I'm not far off. Unless you got a really good motor and can pull a 5th gear over drive, then maybe 120-125. This assumes of course you have enough horse power to rev to 5500 in 4th at that speed.
So what is a "low speed" tire rated for in mph?
Ernie
02-16-2003, 06:13 PM
TX
I just ordered the 275/50's from tire rack.com. These are S speed
rated which is 118mph. I plan to have a set of better tires for the track. I would not feel uncomfortable taking a s speed rated tire
to 130 or so for a second or two on the straights.
02-16-2003, 06:21 PM
Location: Right in the middle of the beautiful Texas Hill Country - Boerne, Texas,
I have the 275/50/15's mounted on an 8" wheel. Just got my new compomotives, and they will be mounted on a 10" wheel soon.
It's hard to find them at Discount Tire..they had to order them in from Houston...2 days...no worries.
blake
"They're lining up on both sides of the ocean..
and nobody's willing to compromise
in the search for the smoking gun..."
"Charlie Don't Surf!"
02-16-2003, 07:36 PM
AL
EXCALIBER,
MY FRIEND, JEFF HAS A UNIQUE WITH A 302, T-5, JAG 3:31, 4 BARREL, MAYBE 270 HP. TOP SPEED SO FAR IS 135 MPH. HE RAN OUT OF ROAD.
TRY ONLINE TIRES. http://onlinetires.com/main.html
EACH COMPANY CARRIES THE TIRE SIZE THEY THINK THEY CAN SELL OR THE SIZE THEY CAN BUY. NOT ALL COMPANIES SELL THE SAME SIZE IN EACH OF THE BRANDS.
02-17-2003, 03:23 PM
IL
Cobra Make, Engine: ERA 454 S.O.
Had a set of 275's monted on 7" rims (not on a Cobra) a few years ago. They were like marshmellows. I definatly ould not use 295's on 7" rims, not even on the drag strip.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
