Old 05-19-2003, 07:57 PM
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
Send a message via AIM to misfit41
Default CSX steering wheel
I am having trouble with steering wheel,t/s clearance,would someone with a csx or an spf mind getting a measurement ? steerng wheel to the dash ,,any where you like ,then steering wheel to the t/s lever ?
again if any one knows the name of the spiral baffles that were talked about here,,I would apreciate the help,,thanks,,Tk
"smoke em if you got em"
Tk
"this whole Adult thing just isnt working for me "
Old 05-20-2003, 12:55 AM
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
I think you'll find your cockpit dimensions are not the same as either of those cars. I'd suggest doing it on a "comfort for the driver" basis.
If you were using an OEM Motolita split ring 16" wheel and hub, with Volkswagen turn signal(which uses lever on the right side of column) the dimensions would then be of more benefit to you.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
Old 05-20-2003, 06:48 AM
Thanks Al,
I am using a motolita wheel,but the 15 inch version,and the vw signal lever with hub,signal to wheel clearance is where my problem lies,I am trying to determine where the difference is,my signal slips on the end of the tube fine,but the wheel wont clear,is there an additional hub or spacer between the wheel and steering tube ?thanks,,Tk
Tk
Old 05-20-2003, 10:42 AM
Dan Semko's Avatar
Hoosier Gashole Emeritus
Wink CSX4308
The measurement of the steering wheel from the center of the wheel to the dash is 4 1/8" and the measurement of the steering wheel's outside edge to the outside edge of the turn signal shaft
(looking through the windshield at the tape) is 1 3/4". This is with the standard 15" Moto Lita Wood steering wheel.
Hope this helps.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
Old 05-20-2003, 11:03 AM
Thanks Dan
Thats what I needed,for the life of me I cant see what I have that is different,but the signal lever hits the wheel,unless they make a vw lever with less offset than mine,but I have looked and cant find one.
thanks again,,Tk
Tk
Old 05-20-2003, 11:09 AM
Cobra Make, Engine: CSX Cars
Dan,
I thought you would have checked the SPF also
Old 05-20-2003, 11:13 AM
Thats a good question,,is the csx pretty much like the spf ?I cant see why i cant duplicate this set up,my switch fits perfectly on the end of the steering tube,but the wheel touches it,is there a hub or spacer between the two ?it would have to be close to 2 inches thick to clear on my car.
Sounds like you have a nice collection Dan,I am a bit envious,as well as for Allans car,,alloy motor in an alloy car,,wow,,!
thanks guys,,,Tim
Tk
Old 05-20-2003, 11:16 AM
Rick Parker's Avatar
Does the steering wheel that you are using have the correct "Dish"? If you are using the 15" Motolita wheel thst was originally intended to be used in the Mustang, it will not have enough dish that creates the clearance you require. Also be sure the correct wheel hub is being used.
Old 05-20-2003, 11:22 AM
My Wheel is dished 1 3/4,,,I was thinking this is correct,,looks right at least,,did the csx cars dim with the lever ? or a floor switch ? {floorswitch I hope,I want one,detroit should have never changed those,,} hehehe
thanks,,Tk
Tk
Old 05-20-2003, 01:08 PM
Dan Semko's Avatar
Allan's car is a continuation series and much further down the production list!
If you need the measurements off the SPF, let me know and I'll be happy to get them.
BTW: the SPF has the leather wrapped 14" wheel so the measurements will be significantly different. I have both wheels for the SPF but the leather, small wheel is more comfortable for cruising and does provide a little extra room.
