December 2025
Old 06-21-2003, 05:55 AM
Cobra Make, Engine: CSX4402
Default placement of Canton remote oil filter
My 351C had this puny filter so I removed and got Canton billet bracket and billet engine plug (with two outlets). The mechanic surprised me when fitting. I also have Mocal oil cooler.
He chose to mount the filter below steering assembly directly in front of oil pan but high enough so it will not bottom out, just in case. It is mounted horizontally. I had seen photos that it is typically mounted on engine bay with vertical position. He claims that since is it neat and tucked away down low less pressure required to move oil around? I think it sucks as the only way you can change oil filter (Canton has replacment 8 micron elements good for 10k) is to lift car.
Any thoughts it this is a good solution?
thanks
Ed
Old 06-21-2003, 07:29 AM
Cobra Make, Engine: Superformance, 396 CI
i have used the 6 1/2 inch Canton/Mecca oil filter on several cars, i have used the screw on one, you have the AN adaptor one, but the inner filter is the same.
They are very high flow, high filtration filters. While it is no doubt a pain to have to jack the car to change the filter, i have to do this on all my cars, (excepting my modified Superformance's system), and besides, it is a good time to get under your car and check it all out.
You can order the filter elements from Pegasus racing, ask for Robin at: www. pegasusautoracing.com
they are very good filters.
Hal Copple
Stroked SPF
"Daily Driver"
IV Corps 71-72, Gulf War
Old 06-21-2003, 09:06 AM
Roscoe's Avatar
Don't you have to get under the car to drain the pan? Might as well take the filter off at the same time. I have to jack mine up to drain and then jack down to change the filters.
Roscoe
Roscoe
Old 06-21-2003, 11:23 AM
I fully accept you 'got to get under' to drain etc. I was only concerned that placement horizontal (obviously most OEM this way) with Canton is fine. The chap rigged it like this- from engine block thru oil cooler then to filter and back to engine. Is this the preferred way or should it hit the filter prior to oil cooler.
Would you also know with a 5 point racing harness which is the "Y" style from the back how in the heck to you keep it from slipping down the sides of the seat. Do you recommend a way to 'hold' it in place centered over the seat? I have 5 kids and want to be sure they are in safe and tight.
Stupid mechanic overfilled oil - I guess it could be a pint or more too much? Is this a problem or simply let it run like this for a while?
thanks again,
Ed
