Old 01-03-2004, 09:10 AM
Default How much leverage is needed....
to disengage a clutch?
I don't have the pedals installed in my car yet...When I bolt the tranny up next week, I'd like to try it in gear since it's been newly rebuilt. If the T/O bearing and clutch fork are installed, could I provide enough leverage by pulling on the fork to disengage the clutch long enough to swap cogs?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 01-03-2004, 03:07 PM
ttt
Old 01-03-2004, 03:30 PM
Default Re: How much leverage is needed....
Not likely, unless you're built like the Guv'nor of California. Figure from 200-500 lbs effort required, depending on your clutch. (That's figuring backword from 40-100lbs pedal pressure x 5:1 mechanical advantage.)
Old 01-03-2004, 05:00 PM
David Kirkham's Avatar
Original Shelby Owner
Not a chance...I've tried it.
David
Old 01-03-2004, 05:05 PM
Well crap. I guess I'll just have to shut the engine down, put it in gear and start it in gear...no wheels or tires on it....a 4.41 gear drive starter shouldn't have much trouble....
Old 01-04-2004, 02:10 AM
xlr8or's Avatar
Unless you have a neutral safety switch hooked up.
