| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
01-07-2004, 12:55 PM
Autometer speedo calibration to car
I have a set of Autometer gauges, the reverse wind 180mph speedometer and the right angled gearbox, I looked on the AM website and they had this information on the speedo:
The speedometer is calibrated for a 1:1 drive ratio (1,000 RPM at 60 MPH input at the speedometer head.) "this was not specific to the cobra gauges!
My question is I know my final drive ratio option , and have Transmission charts indicating what small nylon transmission gear to use with what tire size and final drive ratio.
How do I work out what parts or information I require? - not a biggy as I haven't ordered a trans yet still researching!
A J. Newton
The 1960's rocked!
01-07-2004, 01:02 PM
ME
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Ant-
look on ERA's website, and specifically in the manual that is online. There is a chart which will tell you what speedo gear you need depending on what trans and rear you are using.
Replica is not a dirty word.
01-07-2004, 02:54 PM
Speedo
Chaplain,
Thanks I have that chart, I guess with the speedo being 1.1 ratio 1000rpm at 60mph that is common with most speedos, maybe I am thinking there are different speedo ratios just to complicate things, and the chart has all the information required!
A J. Newton
The 1960's rocked!
01-07-2004, 02:59 PM
ME
Ant-
I never really considered that speedos would have different ratios. However, I have the same speedo and used ERA's chart and I can tell you that it works perfectly! (Well maybe a couple miles an hour off, but close enough.  )
01-07-2004, 03:20 PM
CT
Almost all aftermarket and OEM speedometers are calibrated for 1000 revs/mile (which coincidentally is 1000 revs/minute at 60 mph  ) The only oddball I've seen is a small Smiths that we use in our GT, at 700 revs/mile, and a VDO electronic unit.
01-07-2004, 05:38 PM
Cobra Make, Engine: not yet
ANT;HERES WHAT YOU NEED TO KNOW;
TIRE REVS PER MILE [TIMES] REAREND RATIO [TIMES] # OF TEETH ON DRIVE GEAR [DIVIDED] BY # OF TEETH ON DRIVEN GEAR
= CABLE REVS PER MILE
If you are going to use a toploader just call David Kee transmissions they can set you up with the parts you need.
Bobby
01-08-2004, 02:36 AM
Speedo calibration
Thanks guys, I was complicating the issue, as in the past I got an old Smiths speedo from the wreckers, these varied in a lot of old cars, all different turns per mile etc, imported a 180mph gauge face from the UK and then after calculating the transmission/tires and rear end, if it wasn't right I took it in to a speedo repairer and they altered the magnetism of the instrument, but with these you are unable to take the gauge apart unless you reweld the plastic case.
A J. Newton
The 1960's rocked!
