December 2025
Old 03-14-2004, 09:46 PM
Cobra Make, Engine: ERA 675 - 427 SO
Default Single stage paint vs. base coat-clear coat paint
I wanted to get opinions on the pros & cons of using a single-stage, poly urethane enamel paint, probably a solid black or red, vs. doing the same colors in a two stage, base coat, clear coat poly urethane finish. I began my Cobra project pretty much set on using a two stage paint, probably PPG. After talking with several painters, I am beginning to have second thoughts. A couple of the "Pros" felt that a well buffed-out single stage paint job creates a more classic look on a Cobra. What do you Cobra lovers think?
Old 03-15-2004, 05:54 AM
Cobra Make, Engine: Backdraft, 408 Stroker, 450 RWH
Send a message via Yahoo to CulRad
You will enjoy the Base Coat Clear Coat system best. A dark color loves the clear coat. You can do so much with clear coat, 3M has amazing products that your painter can use to work out the finnished clear coat. They have a system that the painter will use to sand it out, one grit is 1500 and then 3000. Then anytime a scratch gets in the clear coat, it is a simple fix. Clear adds a depth to the paint, have a few extra coats added for good measure.
Old 03-15-2004, 06:41 AM
Cobra Make, Engine: Building ERA #749 427 Cobra
With a Cobra, basecoat/clearcoat is the way to go. You need something that is not so prone to chipping. I have been using PPG coatings for many years and find the poly/single stage paint chips easily and is not so easy to repair. The single stage paints generaly don't give quite the same shine as two stage paints and are more 60's appearing.
Old 03-15-2004, 07:22 AM
clayfoushee's Avatar
Cobra Make, Engine: Unique, 427SO, it runs
I agree the clear coat has huge advantages. My car was backed into at low speed, and there were scrapes over about half the door. I was actually able to wet sand the clear coat and after polishing and buffing, you cannot tell anything happened there. But, I did have the advantage of clear over silver.
You'd be repainting with single-stage.
Clay
Old 03-15-2004, 07:35 AM
PatBuckley's Avatar
I much prefer the classic single stage look - even with all its drawbacks vs. 3 stage.
Old 03-15-2004, 10:31 AM
REAL 1's Avatar
Banned
I prefer single stage. I have glaserit. I can't speak to ease of repairs but I can tell you in black the base coat clear coat looks more like black patent leather. Too glossy IMHO.
The single stage is what they used in the 60's. If you want an accurate looking paint job single stage is the only way to go. It has a nice shine but its not too glossy like two stage.
Old 03-15-2004, 11:24 AM
Club Cobra Member
Cobra Make, Engine: 85 AC MKIV 5LITR , 68 Shelby Cobra GT 500
SINGLE STAGE PAINTS WERE GREAT IN THE 60'S WHEN YOU DIDN'T HAVE TO WORRY ABOUT CHEMICAL FALLOUT ACID RAIN AND ALL THE OTHER CRAP THATS FALLING ON OUR CARS NOW.
I'VE BEEN PAINTING CARS FOR OVER 30 YEARS I EVEN REMEMBER HAND RUBBED LACQUER , NOW DAYS THE ONLY WAY TO GO IS BASE CLEAR, I'VE BEEN USING PPG IN MY SHOP FOR OVER 20 YEARS AND HAVE USED ALL OF THEIR SYSTEMS.
THE REASON THE "CLASSIC 60'S LOOK" WAS THAT WAY IS BECAUSE THE OLD PAINTS COULDN'T HOLD A SHINE WHEN PUT OUT IN THE ELEMENTS, AS FAR AS BLACK LOOKING LIKE "PATENT
LEATHER" SUPER!! THE MORE GLOSS ON BLACK THE BETTER IMHO
Old 03-15-2004, 11:36 AM
REAL 1's Avatar
Banned
To each his own. I don't like the patent leather look.
Not many of these cars are exposed to the "elements". I've had no problem with my single stage and it looks great.
Old 03-15-2004, 10:07 PM
CSX 4027's Avatar
Cobra Make, Engine: Sold 3047 & 3002 in 2012
Default Paint
IMO
Solid Colors - Single Stage Imron (Stronger and more Durable than base-coat clear-coat)
Metallic Colors - Base/Clear. Single Stage doesn't look evenly spread with flake in it.
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
