Like Tree7Likes
Old 11-05-2021, 12:55 PM
NoVA Cobra's Avatar
Cobra Make, Engine: SPF1439 427FE s.o.
Originally Posted by Lou1119 View Post
That is exactly why I put the pushers on my SPF -- for show. However they do help cool the engine compartment after a drive. They do push adequate air through the radiator into the compartment and gets rid of the heat quickly.
So I got the kit from Cobra Restorers - how did you mount yours in a SPF? I see lots of fiberglass shroud around and in front of radiator.
Superformance 1439 w/427FE side-oiler. 2007 GT500 40th Anniversary CSM07XL0078. 2007 GT500 40th Anniversary CSM07XL0085.
Old 11-05-2021, 05:48 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Be extra careful before drilling thru the shrouds. The radiator lives back there. I remember a story about someone wanting to mount a protective screen in front of the radiator and drilling a hole in it. He JB welded a penny to the radiator to plug the hole. How do you plan to power the two pusher fans?
Blas
SPFWiringDiagrams@Comcast.net
Old 11-05-2021, 06:12 PM
Cobra Make, Engine: Superformance , Roush 427SR dyno'd at 526 hp
Blas
I have mine connected to a switch on the dash . It is run through a relay between the fans and the switch
Old 11-11-2021, 08:47 PM
NoVA Cobra's Avatar
How did you mount your fans in your SPF? I have the Cobra Restorers kit and it seems fine, but it's just a bar and a couple of brackets. What modifications did you do to Cobra to mount it? Any pics?
Old 11-12-2021, 06:27 AM
FredG's Avatar
Default Fan Install
Here is the thread of the complete install I did last year. Hope it helps.
New Project - Pusher Fans
Originally Posted by Trueoo7 View Post
Does anybody have any closeup pictures of their twin pusher fans in the car? I'd like to see how they are mounted to the side walls as well as the position of the motors. When seen from the front, do you see the blades first or motors first? Two cross brackets or one? Also what size fuse do you use to protect the circuit?
Would also like to see how front hoop bumper connects to overriders, do they mount to the sides of the overriders or behind them? (since you have the camera out)
Thanks in advance.
Trueoo7
