Like Tree7Likes
Old 03-15-2004, 08:09 PM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Default Pusher fans install ?????
Does anybody have any closeup pictures of their twin pusher fans in the car? I'd like to see how they are mounted to the side walls as well as the position of the motors. When seen from the front, do you see the blades first or motors first? Two cross brackets or one? Also what size fuse do you use to protect the circuit?
Would also like to see how front hoop bumper connects to overriders, do they mount to the sides of the overriders or behind them? (since you have the camera out)
Thanks in advance.
Trueoo7
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 03-15-2004, 08:49 PM
Cobra Make, Engine: NAF replica, 351W, about 420 HP
I know the front bumper bolts to the inside of the overriders....kind of low budget, but that's the way they are.
Edley, The Cobra Rogue!
"If you think that you can cut it, if you think you got the time, you'll only get just one chance, better get it right first time. 'Cause in this game you're playing, if you lose you got to pay, and if you make just one wrong move, you'll get BLOWN AWAY. Expect no mercy.
Old 03-16-2004, 04:15 AM
You can take a look at my picture gallery to see if you get the information you need. I custom made my side mounting brackets but the 2 cross bars and the mounting of the motors/fan blades is as received by Finish Line.
John
Old 03-16-2004, 06:09 AM
CobERA's Avatar
Cobra Make, Engine: ERA #644 428 FE
Neutral
I bought the kit from Finish Line, but made my own mounting hardware. See the picture below. The mounting bar is steel stock I purchased from Home Depot (1" I think). The mounting brackets are made from angle brackets and a short sleeve made also from steel stock from Home Depot and a flat piece of steel stock on the ends. The sleeve is the next size up steel stock. I wrapped the end of the mounting bar with some red gasket material that I purchased from Sears. With the gasket material on the end of the bar, it is just the right thickness to slip into the sleeve. The brackets that attach the fans to the bar were fashioned from an angle bracket that is used for building decks. It had a small hole in one side of the "L" that I drilled larger to allow the spindle of the motor to fit through. I did a little trimming on the bracket so that it did not show from the front. I polished it all up and gave it a coat of POR-15 clear coat.
Here is another shot from straight on.
Rick
ERA 644
I'm getting old too fast and smart too slow!
Old 03-16-2004, 11:25 AM
lineslinger's Avatar
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
I have read that pusher fans restrict too much ariflow to the radiator and should not be installed, opinions, ideas?
Old 03-16-2004, 11:31 AM
The only thing I've heard is that you don't want to use both a pusher and puller at the same time as it could create "turbulance" and make your airflow go around the radiator instead of through it.
John
Old 03-16-2004, 03:08 PM
Rick
Thanks for the photos that really helps alot. Couple of questions...How far would you say the fans are from the radiator? 1"-2" ??? I'm not sure why you used the red gasket material. Was that to take up any slack inside the larger tube because it looks like you bolted the brackets to the cross bar which would have tightened them up anyway? Also what size fuse did you use to protect the circuit? The POR 15 that you used....did that come in a spray can and did you spray it on the motors too?
Question for anybody: Does a hoop bumper come with some sort of side brackets already on it, and then you have to adapt that to the overriders?
Thanks again
Trueoo7
Old 03-16-2004, 03:29 PM
CobERA's Avatar
True007,
To space the fans from the radiator I put about four layers of corrugated cardboard, so they are quite close ... maybe a half inch or so.
The gasket material did just take up the slack, but it did make it easier to install the whole setup with the brackets tight on the mounting bar. I cut the mounting bar a little shorter than the width from sidewall to sidewall, that way I could slide the brackets a little to assure a proper fit. A little WD40 provided the lubrication.
My front fans are wired to the same circuit as the puller fan. ERA's wiring harness splits to allow that. I did not put the front fans on a separate fuse. Finish Line provided one. I'll take a look tonight to see if I can find it.
The POR product was a brush on product, "Glisten PC" I think. I applied it to the mounting hardware, fans and motor.
So far I have not noticed any problems as a result of having the front fans, or running them at the same time as the puller fan. I cruise at about 180 and when idling get up around 190. The fans kick in at around 180 and seem to work well.
Rick
ERA 644
Old 03-16-2004, 08:03 PM
Rick
Thanks for all the help, hopefully I will be installing mine sometime next week. I'll let you know how I make out. I'm off to Home Depot !!
Trueoo7
Old 01-04-2020, 12:10 PM
Each pusher adds about 500 CFM of airflow.
Never been an issue with flow blockage even on 90 degree days (puller on & pushers off).
When in stop/go traffic pushers "on" drops the radiator temp right away.
A side benefit is they slice and dice bugs before getting into the radiator.
Old 01-04-2020, 03:26 PM
Cobra Make, Engine: Superformance , Roush 427SR dyno'd at 526 hp
Originally Posted by Trueoo7 View Post
Rick
Thanks again
Trueoo7
Typically the front nudge bar comes with the side brackets attached. You will have to play with the fit but in all likelihood you will have to adjust the over riders from where they attach to the inside of the fender wells. That is what I had to do on my SPF or the over riders will not be straight when viewed from the front. A bit tedious but worth it.
Old 01-04-2020, 03:34 PM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
Default pusher fans
This is on my CSX car
Old 01-04-2020, 03:37 PM
I bought the pusher fans and mounting bar from Cobra Restorers. Nice kit but still needed some modifications to get them installed. I had the kit for a month or so and played with how to to mount the fans. I know that the fans on the original had the motors to the front but I didn't like it so mine are mounted with the fan blades to the front and the motors to the rear. I ran the wiring through the inside of the bar so there are no wires visible. Since these cars are replicas I felt that you have some creative liberties and can cook the soup to your tastes😎
Old 01-04-2020, 05:24 PM
snakeeyes's Avatar
Resurrecting a 16-year-old thread? I hope Tru007 has solved his fan issues by now
Old 01-09-2020, 04:59 AM
Slow down, these things take time. I just got back from Home Depot (it was crowded) and hope to install them this weekend.
Yes I did mount them but I had some issues. I got the fans mounted but not before putting on a screen to help protect the radiator. Unfortunately I mounted them too close and being the fans are aluminum, they would bend in the wind and as they spun they would rub against the screen which caused a hole. I think the whole bracket might be a little loose too so I need to fix that.
I still have the front bumper but I never mounted it. I have stainless steel over riders and the thought of trying to accurately drill mounting holes through them without a press is a little daunting.
Good news is, I now have a 4 post lift so it will be easier to fix. Check back in 16 years, hopefully by then I should have them mounted.
krausewich and CCKW353 like this.
Old 01-10-2020, 12:50 PM
Cobra Make, Engine: NAF 427 SC with 429 Cobra Jet motor, toploader 4 speed
Everyone has a different experience so here's mine. I've never had a pusher fan work as well as a puller, either on my Cobra replica or my circle track cars. To cool my Cobra (429 SCJ engine) I had to go with an aluminum cross flow radiator, twin electric puller fans with shroud, and a Dakota Digital fan controller. IMHO if anyone can cool a big-inch, big horsepower engine with pusher fans, you're really lucky.
Gaz64 likes this.
Old 01-10-2020, 01:04 PM
cycleguy55's Avatar
I believe most of those running pusher fans are doing so as secondary or supplemental fans to puller fan(s). As such the pushers are there primarily for decoration.
Brian
Old 01-12-2020, 08:12 AM
Club Cobra Member
Twin pusher fans for show. They really look cool spinning in the wind.
Puller fan/fans for go. That hot air has got to go.
Greg
Dwight, ERA 626 and cycleguy55 like this.
Old 01-12-2020, 10:05 AM
Greg
That is exactly why I put the pushers on my SPF -- for show. However they do help cool the engine compartment after a drive. They do push adequate air through the radiator into the compartment and gets rid of the heat quickly.
cycleguy55 likes this.
Old 01-14-2020, 09:42 AM
Club Cobra Member
But I do love the look!
Greg
