| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
03-20-2004, 07:10 PM
NT
Bonnet scoop
I want to mount my bonnet scoop to the bonnet, I need to know how far from the leading edge (front) of the bonnet to the front of the scoop?
Also is there any specific size and spaceing for the rivets?
I dont want to be drilling holes everywhere then find out I have it all wrong.
Thanks in advance.
Cruising in 5th
03-20-2004, 07:54 PM
FL
Cobra Make, Engine: Past owner ERA 146, ERA 694 in progress, 428 CJ, toploader
Hood scoop
Ah..the great rivet debate begins again..
Go here, http://www.erareplicas.com/427man/body/hood.htm
its (usually) accepted as accurate, but opinions vary.
Good luck
John
03-20-2004, 08:47 PM
NT
Am I looking at the diagram correct in that the scoop is central in the bonnet but the cut out is 1 inch offset?
Cruising in 5th
03-21-2004, 02:14 AM
Zzz
Hi Boxhead sounds like you are making good progress.
Instead of rivets I used button heads in stainless.
You may recal when you were over, I have also placed the bolts through the bonnet/hood edge. Here I started at the front of the scoop and went around to the front of the scoop.
Used the same button heads here as on the scoop.
Just don't over tighten them.
Bernie
Bernie Knight
03-21-2004, 02:17 AM
Zzz
Just don't over tighten them. Email me if you need measurements after checking out the sites here.
Bernie
Bernie Knight
03-21-2004, 03:40 AM
NT
I do remember seeing yours Bernie and have the pics, but when you say Button heads do you mean like little bolts with a round head and no screwdriver notch in it?
If so where did you get them?
The progress has been slow (in my eyes) lately.
I am half way through doing the selector mod on my T56 box, all the parts are cut but I wont get time to weld it all together till next weekend now.
I priced a set of Smiths gauges for my car, 300kph speedo, tacho, fuel level, oil pressure, water temp, oil temp, amp & clock with all senders. I nearly died, they wanted $2000.00AU black faces, white dials & chrome bezels.
Does anyone else now of another gauge set with similar features for less money?
Cruising in 5th
03-21-2004, 08:21 AM
OR
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Boxhead:
Have you looked at the Autometer set that Finishline has? Don't know what the cost would be given the exchange rate but it might be an improvement.
DonC
03-22-2004, 04:59 AM
NT
I found out that where I work we are actually autometer agents so the guys in spare parts are going to get me a price.
Cruising in 5th
03-22-2004, 05:58 AM
Zzz
Hi Boxhead, sounds like you are really progressing if your looking to bolt/rivet scoops etc. on.
I used the VDO gauges and VDO (Roger Howard from Howard Instruments in Northern Rd, Heidelberg Victoria) have the Smiths face on them compliments of Rogers expertise.
All the nostalic/original look but totally electronic. Full set including clock was around $1200 with all sender units for temps. fuel etc.
The button heads are semi circular/dome shape with an Allen
head top insert.
Available in all bolt shops or try Portland Fasteners in Portland Victoria who supplied mine. They posted them to me ex Visa card processing.
I can soon send you a sample. Email me at;
kni-time@bigpond.com
if you want one as a sample
I used nylocks and just tightened them until they were firm. I will watch it once its all painted, with the tightening, as I have seen some real spider cracks on some cars.
Bernie
Bernie Knight
03-22-2004, 08:43 PM
CA
Cobra Make, Engine: Contemporary Classic CCX 3970: 1965 427 Cobra S/C, Shelby aluminum 427 CSX 290 (468 cu in) engine
Boxhead: I'm not sure about Down Under, but here in the states Nisonger is the place for Smiths gauges. They are remanufactured using the original Smiths tooling. Peter Bayer of Contemporary Classic fame is the man, back in New York. His email address is info@nisonger.com and his toll free (here anyway) phone number is 888-781-6968. In my opinion, there's nothing better looking (or more authentic) than a set of Smiths gauges on a 427 S/C dash. And that funny reverse speedometer even makes sense for you guys driving on the wrong side of the road! ; ) Rich
03-22-2004, 09:03 PM
NT
Down here we sit in the right(hand) side of the car, so maybe you guys have got it all wrong?
I will send an email to Peter as at this stage I am only looking around.
Thanks for the info.
Cruising in 5th
03-23-2004, 05:35 AM
NY
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
In an ERA the motor is offset 1" to the right. Before cutting a hole in your hood check to see where the carb is relative to the scoop.
Jim
03-23-2004, 05:42 AM
NT
Thanks for the report of the era engine being off centre, but I have a LS1 engine going into mine.
No carbies, but hopefully later I will get a 8tb setup
Cruising in 5th
