Old 05-15-2004, 02:45 AM
Senior Dragontamer
Cobra Make, Engine: Kirkham, 427 S/O
Supercobra,
If you are running a single 4V carb, the isolator location in the photo is great. I'm running dual quads with banjo fittings to the carbs that keeps the fuel lines inside the linkage and had to move the oil tank slightly outboard so my isolator plumbing coming off the back of the second carb cleared the oil tank cap. Depending upon your setup, you may want to rotate the isolator 90 degrees from the one in the photo. In any case, the isolator is hidden very well under the oil tank. Good luck and don't drill holes in the firewall until you are sure of the location and what is on the other side.
Jeff
Old 05-15-2004, 04:49 PM
PatBuckley's Avatar
David-
Sounds like a lot of work to do as a volunteer.....
Pat
Old 05-15-2004, 05:07 PM
Jamo's Avatar
Super Moderator
Listen to U2 about not drilling until you know what's on the other side. That's why that motorized glider he flies leaks fuel.
Jamo
Old 05-15-2004, 06:57 PM
Senior Dragontamer
Jamo,
About once a month my Maintenace Operations Center calls in the middle of the night to tell me how my guys broke an airplane while trying to fix it. I am a firm believer of, "If it ain't broke, don't fix it."
Old 05-15-2004, 07:32 PM
Jamo's Avatar
Super Moderator
A big assolutely on that, Jeffy.
Jamo
