Old 05-17-2004, 05:19 PM
Banned
Default Electrical 101 - I really suck at this....
Friends,
Here's my situation. I have a digital multi-meter and I want to test the output voltage coming from the "tach output" on an MSD 6AL. This is typically a single wire that goes from the MSD box to the tach signal wire (or to an MSD tach adapter). On an SPF, the tach signal wire is black/green.
My tach is dead and I want to test the MSD 6AL for output voltage. A reading of 1-5 volts is normal....a full 12 and the MSD box (tach output connector) is bad and needs to be fixed at the factory.
On this digital multimeter I'm a total novice on "what" and "how" to probe. I know enough to set the dial to 20V (20 volts or less), but I have no idea where to probe the black wire to complete the circuit.....ground????
I feel so stupid....
-Deano
Old 05-17-2004, 05:34 PM
MOTORHEAD's Avatar
Black (-) to ground. I assume you came up with the voltages from
the mfrs instructions or trouble shooting guide. It should tell you
if your'e measuring AC or DC. Set your meter accordingly.
Good Luck, remember, Edison started somewhere !!!
Old 05-17-2004, 05:39 PM
Banned
Yeah, I even did my 5th grade book report on him. Look where it got me!
Old 05-17-2004, 05:58 PM
xlr8or's Avatar
Black to ground. If it sparks it's wrong.
Seriously. Set the multimeter <20 VDC. Put the red on the tach output and the black to ground.
Old 05-17-2004, 06:50 PM
jackwsmith's Avatar
Cobra Make, Engine: NAF 1970 SC 428CJ
Smoke is NO GOOD
Jack W Smith
Old 05-17-2004, 10:24 PM
Banned
Jack, thanks!
Okay....I'm pulling a little over 2 volts at the tach output, which is good news (should be between 1 and 5 volts). At least that tells me that the MSD box tach function is working. I'm now 99% confident that the tach board is fried and needs rebuilding. I'm sending the unit out tomorrow to "MO-MA Instruments" in Albuquerque, NM for some higher quality "German" circuitry work. It was either that or send it to some outfit in New York (in which 3 people I spoke to there gave me 3 different answers and 3 opinions).
-Deano
Old 05-18-2004, 10:55 AM
RallySnake's Avatar
Deano,
Maybe I can help you with this. But, I need to know more.
What brand of tach is it? Did it ever work? If so, change did you make when it failed? Do you have a ground wire to the body of the tach?
Paul
Old 05-18-2004, 11:44 AM
Banned
Paul, it's a SPF factory Smiths tach. Worked fine until I disconnected my ignition system (MSD 6AL, etc.) for maintenance. When I buttoned-up the ignition, the tach started to bounce and then it went dead. The tach is wired with one, 5-wire connector plug. I guess it's possible for a bad ground, but the circuit (according to the SPF owners manual) is also shared with other instruments and components. So I don't suspect a ground problem, as all other components are functioning. I have also researched this problem and apparently it's hit or miss with Smiths tachs and MSD ignitions. The tach has a weak circuit board and is prone to failure from voltage spikes.
The new circuit board that I'm having installed will allow me to bypass the MSD box altogether and go straight to the (-) side of the coil (as was factory installed).
-Deano
Old 05-18-2004, 03:24 PM
Mr.Fixit's Avatar
I never (or very rarely and don't recall) seeing a fried Smiths tach from use with an MSD, I have seen plenty that just plain didn't work with an MSD, until an extra capacitor and tach adapter were added.
Old 05-18-2004, 03:47 PM
Banned
Not sure what is going on with the tach, but it no worky. Now if I get it back from MO-MA's in 2-3 weeks and it still doesn't work, then I'm going to be real peeezzzed off.....
Old 05-18-2004, 04:03 PM
RallySnake's Avatar
Deano,
I suppose you've read the MSD manual. If not you can see it here: http://www.msdignition.com/pdf/6series.pdf
I have no experience with Smiths gauges, but I have a lot of faith in MSD products. They offer two adapters which are mentioned in the manual. One for magnetic pickups and another for white wire connections. Thats the way I'd go before sending the gauge off somewhere.
In any case, I wish you luck,
Paul
Old 05-18-2004, 04:07 PM
Banned
Paul, I've read the manuals and had MSD on the phone at least 3-4 times. I bought their recommended tach adapter and still no luck. The MSD unit is sending a signal, and I trust a brand new tach adapter, so I'm left with having the tach diagnostically checked and repaired (if warranted). Thanks for the encouragement!
Old 05-18-2004, 04:11 PM
RallySnake's Avatar
Deano,
Electronics has been my profession and hobby for 30 odd years. If that tach doesn't work when it gets back, bring it over and we'll get out the BIG hammer!
Paul
Old 05-18-2004, 04:14 PM
Banned
Deal!!! LOL
Old 05-18-2004, 07:08 PM
Cobra Make, Engine: Midstates, Genesis 427 S/O
Deano,
You said you have a cluster plug? More than likely, you do have a ground in that, don't assume it's good just because all the other instruments are working. Does your voltmeter have the ability to check ohms? If so, take a reading from the ground in the cluster (black wire) to another ground. You should read 0-2 ohms if the circuits good. They teach us that electricity flows, but the truth is , it stumbles around like a drunken sailor. Let me know what you find.
Chris
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
Old 05-18-2004, 09:13 PM
Banned
Chris, I'll have to check it out and report back to this thread. Can't get to it this evening though....maybe tomorrow.
THANKS for the tip!
