Old 06-13-2007, 07:07 AM
Cobra Make, Engine: Sold Backdraft #488 Roush 427R
Default Changing oil
How often do you change your oil?
Besides putting the car on a lift what is the best way to get under the oil pan?
I jacked up the front end to get under the pan on my first oil change but thought it would be easier driving the front end up on some blocks? Any tips would be appreciated.
Peter
Old 06-13-2007, 07:39 AM
I put mine on 2x10s -- it gives you plenty of room and is pretty safe from collapsing (don't forget to chock the rear wheels). Of course, I still manage to spill oil all over the driveway....
Old 06-13-2007, 07:41 AM
rdorman's Avatar
Renegade Nuns on Wheels
Myself in my street driven (IE, not raced) car, every 3000 or once a year which ever comes first with a filter change in between. Get a mighty vac and never get under the car again for oil (depending on pan configuration and dip stick location). Or get some ramps from the local parts store.
OhioCobraClub.com
LondonCobraShow.com
Old 06-13-2007, 08:50 AM
Thanks Patrickt for the picture thats what I was thinking.
Rdorman, will the front of the cobra go up the metal type ramps you can get at any parts store without bottoming out on them?
Old 06-13-2007, 08:54 AM
rdorman's Avatar
I bought the 'plastic' ones and no problem. My car sits very low. Of course you could just drive it there and see!
OhioCobraClub.com
LondonCobraShow.com
Old 06-13-2007, 10:06 AM
Roscoe's Avatar
I use the Aeroquip quick drain fittings. No muss, no fuss, just snap the coupling on and drain. Also, you won't have to keep taking the drain plug off and eventually strip the threads.
http://www.racerpartswholesale.com/aero4.htm
Roscoe
Old 06-13-2007, 10:47 AM
Sal Gerace's Avatar
Cobra Make, Engine: CSX4300, C5AE-H, Toploader
Why is it that when I remove my oil filter from my remote filter the oil drains out and spills all over. Is there pressure built up in the remote setup? Is that normal?
Old 06-13-2007, 11:00 AM
rdorman's Avatar
Sal, normal
OhioCobraClub.com
LondonCobraShow.com
Old 06-13-2007, 11:02 AM
Roscoe's Avatar
I usually put a plastic bag over the filter before I take it off. Cuts down on alot of mess.
Roscoe
Roscoe
Old 06-13-2007, 11:18 AM
Sal Gerace's Avatar
thanks guys
Old 06-13-2007, 12:37 PM
wtm442's Avatar
Beam Me Up Scottie
Overflow of the oil filter when removing is usually that part of the oil line(s) to the remote cooler or block is higher than the filter.
I just changed my synthetic Red Line oil at 5K miles. It was BLACK and I was pleasantly surprised that there was nothing stuck to the magnetic drain plug. Oh, and I only spilled about 1/2 a quart on the ground.
Warren
Old 06-13-2007, 12:56 PM
65cobra1's Avatar
Cobra Make, Engine: SPF #2450, Roush 342RE
That part looks like a great idea...I'd like to order one before I make my next oil change then have it ready to install.
Any idea of the thread specs on an SPF 7 qt Canton oil plug?
Thanks, Ivan
Forget the health food...I need all the preservatives I can get !!!
Old 06-13-2007, 01:00 PM
Roscoe's Avatar
Don't know the thread size for the Canton pan. I have the Milodon Road Race pan. Maybe someone here can answer that question or call Canton.
Just permenantly attach a short hose to the blue part and it drains right into your drainpan.
It's really one of those "gotta have" parts.
Roscoe
Roscoe
Old 06-13-2007, 02:59 PM
BDHE's Avatar
Cobra Make, Engine: Superformance, PE 514
Gents;
Eric at Performance Engineering just pulled a plug out of a Canton oil pan for me, checked it, and says they use 1/2 - 20 threads.
Bryon
Old 06-13-2007, 03:32 PM
Ant Ant is offline
Roscoe,
Great tips with the benefits of your experience!
peters44,
Have you got a friend with a hoist, as with this type of car, its a real good idea to wipe down and have a good look at everything and if necessary run a spanner over, checking for leaks and potential problems!
A J. Newton
The 1960's rocked!
Old 06-13-2007, 03:45 PM
Yes Ant, I have a couple places to lift the car to go over everything.
Rosco, thanks for the Link. I'm going to find out what size I will need for my Roush 402.
Old 06-13-2007, 09:42 PM
65cobra1's Avatar
Originally Posted by BDHE
Gents;
Bryon
Thanks, Byron...'preciate the help.
Ivan
Old 06-14-2007, 02:14 PM
Snakebit's Avatar
I like the plastic bag over the filter to prevent oil from dripping on everything. I've tried those quick coupling connectors from Fram that attatch a hose to the drain plug. The problem was it left dirty oil in the pan. If I jacked up the car on the opposite side, another pint of oil would drain out.
Snakebit
Old 06-14-2007, 02:22 PM
Sal Gerace's Avatar
Now for another problem... I have a 427 with a 2x4 manifold. When I need to fill the engine with oil the oil fill tube takes forever to drain the oil into the engine. Usually if I am not paying attention and some of the oil spills out. Any suggestions. No provisions in the valve covers and I don't want to change them. I'm screwed huh..
Old 06-14-2007, 02:56 PM
imagine2frolic's Avatar
Cobra Make, Engine: n/a
Send a message via Yahoo to imagine2frolic
A funnel will help.
20mph is not fast, unless you are doing it in a 3/2, 1000sq. ft. house on 10 ft. waves!
