What's involved in "setting up" the suspension?
I have a Contemporary with Jaguar rear suspension. I've often heard about guys having their suspension "set up." Once I have my ride height set, exactly what's involved in getting the suspension adjusted and balanced correctly? I remember reading a thread recently where a guy said his car wasn't really pleasant to drive, but after his suspension was adjusted correctly, it was a night and day change. Can someone walk me through the steps, what to do, what tools are needed, etc? Thanks!
Toe in, caster, and camber. It can be done with lazers or string. I'm sure someone here can get real detailed. We used to do it with string on formula cars back when. It involved setting up two parallel lines just outside the wheels. Tire pressure had to be checked first then using a tape, measuring the toe in was checked front and rear. The rear toe in was very critical. A castor camber guage was used to measure those parameters. When one thing was changed it affected another. So on and on it went.
John |
Simple front and rear wheel alignment, that's all? I was assuming there were spring tensions and settings to be changed, maybe scales under the wheels to assure that there was some sort of set weight on each wheel, etc.. Again, this is all just a guess here, but I always assumed that it was more than just a simple front and rear wheel alignment involved. I guess I just though it was a lot more complicated than that. Anyone?
Start with basic ride height and tire pressure.
Front end alignment is a good start. Just like any street car, if the alignm,ent is off, it's tough to drive. Then you have to align the rear wheels. Pretty much the same as the front, except no caster. Make sure toe and camber are correct. Finally, you want to get your corner weights checked and adjusted. Having the car properly balanced makes a lot more of a differance that you think it would. Once you have all that done, go back to the beginning and check it again. Changing one thing often changes another. It's a tedious and time consuming process. Generally takes me all day to do mine. But worth every minute. |
My Hi Tech was set up by Tom Barnard of Tom's racing in Vegas. It wasn't cheap. I think it cost about $600.00 or 700.00 dollars and can take 8 hours. This was set up far better than probably required for street use. Measuring corner weights isn't really required but does complete an alignment. Changing the spring perch on one corner also raises the car slightly and so off you go again. I can give you the number of Roger Bolick in Austin and he can run you through a basic alignment. Most big cities have someone that's a "go to guy" for a cobra or race car alignment. PM me if you want Roger's number.
John |
Set up
I do it for track cars in this order
Ride height Corner weights Cross weights Roll center Corner weights Castor Camber Toe Bump Steer Repeat for bump steer changes It's a full day and then some depending on how fast you want to go Fast = Expensive Quote:
Steve,
Thanks for the comprehensive list. Anyone know of a good book to buy that explains how to do it? Unfortunately, I'm not even familiar with half those terms. :CRY: |
Search for "Tune To Win" on Amazon.com It's by Carroll Smith and is a no nonsense approach to chassis set up. Or go to: http://www.carrollsmith.com/main.html
It was a bible I used for many years. If you intend to race it is an absolute neccessity along with engineer to win. John |
Books
Carroll Smith books are great
Circle Track Magazine has great set up articles even if your not just going in a circle. Either search their back issues or subscribe. |
I just had my suspension set up at a shop here in Atlanta. They have a table they set the car on make the adjustments. They are essentially a Porsch racing team and perform this process on their track cars all the time. Probably something you want to have done by someone who's set up to do it.
At Lime Rock Park ( CT ) for the ALMS race yesterday, Teams bring their " surface plates' for setting up the race cars:
An alignment platform is an aluminum structure incorporating easily assembled components enabling the user to construct a level surface to execute chassis set-up on a race car. Chassis set-up includes: Wheel alignment Castor, camber, toe-in/out Chassis rake (front to rear, side to side) Wing angle Total and individual wheel weights The key to productive testing and a successful race weekend is being able to find a flat level surface on which accurate and repeatable measurements can be made. Testing can become very non-productive or minor damage during a practice session can ruin an entire weekend if you can't accurately reset the suspension. Indy car teams have long recognized these facts and have constructed elaborate surface plates which cost up to $20,000 and needed a semi-trailer to transport! Alignment Platforms are also known as Set-up platform, Set-up rack, Scale platen, Chassis set-up fixture, or the English term, Flat patch. http://www.advancedracing.com/produc...prod=platforms |
| All times are GMT -7. The time now is 11:34 AM. |
