Old 07-23-2007, 01:44 PM
CobERA's Avatar
Cobra Make, Engine: ERA #644 428 FE
Patrick,
I am using an MSD-8200, which is oil filled. I just pulled the installation instructions and found the section on mounting orientation. It does look like mine should be mounted vertically. So to eliminate one possibility, I'll either find a way to vertically mount the coil or buy an 8222.
ERA 644
I'm getting old too fast and smart too slow!
Old 07-23-2007, 01:53 PM
Chaplin's Avatar
Rick-
If you have the edelbrock cylinder heads, there is a bolt hole on the front of the driver's side cylinder head- mount the coil bracket to that hole and you will be good to go.
Replica is not a dirty word.
Old 07-23-2007, 01:57 PM
CobERA's Avatar
Chaplin,
I have iron CJ heads, but I think there is a bolt hole on the driver's side front. I'll check tonight.
ERA 644
