Old 07-29-2007, 05:12 PM
Bryan Wilson's Avatar
Default Compression and cam
Does the cam timing and the overlap (degree of lobe separation) affect compression ratio.
Bryan
VK3KDN
Old 07-29-2007, 05:15 PM
wtm442's Avatar
Beam Me Up Scottie
YES. But only to a very little effect. The effect dissipates to almost no effect as the RPM's increase.
Warren
Old 07-29-2007, 05:43 PM
jwd's Avatar
jwd jwd is offline
Very much so. You're talking Static vs. Dynamic compression. The street racers rule is to build it (compression ratio) with the pistons and take it out with the cam. It's all about intake valve closing.
Old 07-29-2007, 05:59 PM
Aussie Mike's Avatar
Sure does make a difference Bryan. I've got a bigger cam for my motor but I'm looking at some heads with more comp to take real advantage of it. Bumping up the compression will give you a good boost in torque.
Mike Murphy
Melbourne Australia
Old 07-29-2007, 06:04 PM
Bryan,
It doesn't effect static compression ratio, but it does effect dynamic compression.
It also drastically effects cylinder pressure, and the effect varies throughout the RPM range.
Dynamic compression doesn't take into account the ram effect from the moving column of air in the intake which causes cylinder pressure to vary by different amounts at different RPMs.
Have a look at these for a brief overview:
http://members.uia.net/pkelley2/DynamicCR.html
http://www.kb-silvolite.com/calc.php?action=comp
http://www.hcs.harvard.edu/~jus/0303/kuo.pdf
http://www.vehicular.isy.liu.se/~lar...d_2002_SAE.pdf
Kevin
