| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
2Likes
Post By Bumpster
Post By scootter
08-08-2007, 01:05 PM
FL
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
Goodyear F1 Tires
Does anyone have any feedback good, bad or indifferent on these tires? I have a BDR coming next week and trying to decide which tire to have mounted on the 17" knock offs....
Thanks,
Mark
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
08-08-2007, 02:38 PM
Got them on my Lonestar, 600 HP & 600 Tq & they have impressed me on bite but they also bite Rocks & throw them ! I checked with other Cobra guys running them before I bought mine
08-08-2007, 02:49 PM
Club Cobra Member
Fl
Cobra Make, Engine: Hunter FIA style body with Ford suspension, 351W/396 by Southern Automotive
I've been using them for two years. I believe they are the best street tire you can get. They were the highest rated tire in their class by Tire Rack when I bought them and I'll keep using them until something better shows up. They are not the cheapest tire available, but then nothing on my car was bought because it was the cheapest part available. The way I see it, if you want to maximize the performance of your car, tires can make the difference whether all the performance is utilized or not.
Bumpster
08-08-2007, 02:55 PM
Club Cobra Member
PA
Cobra Make, Engine: Superformance 460/514 stroker
I have them on my SPF since April 07 and they are great on the front 275/40ZR 17 and the rear are 315/35ZR 17 and with a 514 ci at 626 fwhp they do the job !! Make sure you get the correct back set on they wheels to clear the fender wells and the frame.
bob514
08-08-2007, 03:40 PM
TN
Cobra Make, Engine: Backdraft 342 Stroker, 400hp
Purchased our BDR in Sept. '05, chose the Goodyear F1 over the Nittos because of the compound being a little harder and longer wear life. 4400 miles later, I know we made the correct choose. Still like new tread wise and handle and ride great for street tires. Also understand that they are easier to keep in balance. Keep 29lbs. front, 28lbs. rear with the 342 small block.
08-08-2007, 05:02 PM
Ca
Cobra Make, Engine: SPF #1436 514
I had the F1 Supercar tires 275/40 ZR17 front and 315/45 ZR17 rear. They hooked up well, but I recently switch to the Michelin Pilots and went up to the 335's in the rear. They hook up alot better. That little bit of extra tread with over 550 RWHP made a big difference.
Scott
08-08-2007, 05:21 PM
FL
Cobra Make, Engine: Backdraft #406
You can't go wrong putting the F1's on your BDR, I'm running 28 psi in the front and 30 psi in the rear.
08-09-2007, 04:15 PM
Ca
Cobra Make, Engine: 2001 SPF, Sold =(
I run Goodyear Eagle F1 GS-D3 on my 2003 Cobra. They are 295/35/17 rear and 265/35/17 fronts. I love these tires. My car makes 450 rwhp and they hook (and look) great.
08-09-2007, 09:00 PM
Tx
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
Have them - love them. Great wear and grip.
08-11-2007, 09:26 AM
MD
Cobra Make, Engine: Unique, 427SO, it runs
They are very good tires. The F1 Supercar runflats (with a different tread design) are the only tire available on C6s and Z06s.
Clay
08-11-2007, 11:45 AM
I had the F1 GS D3s on my Vette. They were awesome. What I liked the most was that they were very predictable when they broke loose vs. the stock F1 runflats, additionally they were much quieter than the stock F1s.
