Old 08-15-2007, 03:11 PM
Terry Stapley's Avatar
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Default Tremec Neutral safety switch
Where does one find a neutral safety switch for a Tremec TKO 3550?
Does anyone have a part number and supplier??
Thanks in advance!!
Terry
Old 08-15-2007, 03:42 PM
Frank Messina's Avatar
Cobra Make, Engine: FFR, V8, Manual Trans, Htr, Wipers, Radio Delete
Did you try Mike Forte 508-875-0016?
Frank
Old 08-15-2007, 06:29 PM
Dan Semko's Avatar
Hoosier Gashole Emeritus
Look on the drivers, upper side of the transmission. There will be two wires
(on the older versions and I believe 3 on the newer)that loop towards the rear of the trans. If you want to over ride the neutral lock out, cut the wires from their attachments and bridge them together with a connector. If it has the 3 wire, wind the wires together and test the neutral start before you permanently connect them.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
Old 08-15-2007, 06:38 PM
Cobra Make, Engine: SPF 545" stroked 460 - sold
The 3550 and TKO 500-600 series apparently use the same neutral safety switch, at least when I was looking into this a while back. Info source and parts source try Jimi at http://www.standardtransmission.com/
