| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
08-15-2007, 07:50 PM
ca
Cobra Make, Engine: FFR, CHP 427w Streetfignter, Injected Venom.Mass-Flo...550 hp , 550 torq..spec pulley sys..
side pipes have melted bags .....help!!
WEll, i come out and there is this smell...and it is a melted plastic bag of sorts.....melted on the sidepipe.
how do you get this off? is there anyone that really knows this problem?
thanks guys! BTW these are ceramic coated ones.
fred z
Passion......"many things in life will catch your eye....but only a few will catch your heart......follow that one!"
08-15-2007, 08:44 PM
Tx
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
I used a very light scotch bright pad. Did OK, but it was a PITA!
08-15-2007, 09:20 PM
Ca
Cobra Make, Engine: SPF #1436 514
Fred,
Go out a drive the car and get the pipes hot. When you get home, get a wet rag and wipe it off( don't burn your hand, the rag will get hot). Some of it might be hard to get off. When it got to that point, I wrapped the wet towel around a plactic putty knife and got the rest off.
Scott
08-15-2007, 09:24 PM
CA
Some people have had good results using lacquer thinner:
http://www.clubcobra.com/forums/showthread.php?t=79014
Doug
Doug
08-16-2007, 04:09 AM
How about some MEK (methyl ethyl ketone)? I had access to it in my younger days. It would "melt" plastic bowls..
Too many toys?? never!
08-16-2007, 06:56 AM
MD
Cobra Make, Engine: Unique, 427SO, it runs
Been there, done this........with a melted car cover on both sides during a sudden rain storm, that blew down over hot pipes.
For ceramic sidepipes, #0000 steel wool, and a green Scotchbrite pad will remove all traces. Use a bucket of clean water, and keep soaking both. Start with the Scotchbrite and finish with the steel wool. Use as little pressure as necessary. No chemicals are necessary. A light brush with the 0000 up and down beyond the residue area will blend in and clean up the rest of the pipes.
It helps if you drive at least 100 or more miles first to burn off as much of the residue as possible. Then, it's a fairly easy clean up.
Clay
08-16-2007, 06:58 AM
TN
Heat the pipes...wipe it off.
08-16-2007, 10:33 AM
ct
Cobra Make, Engine: Venom 351W Mild Cam 600cm Holley MSD T-5
Used wd-40 once it cooled. worked great.
joeg
08-16-2007, 11:26 AM
MO
Cobra Make, Engine: 2001 SPF
I heated my sidepipes up and rubbed the melted spot with ice cubes. The melted plastic just started flaking off. Nothing else that I tried would work, then someone told we this and it was easy.
08-16-2007, 12:21 PM
CA
I've heard oven cleaner on the warm pipes will allow it to be wiped off clean.
08-16-2007, 12:26 PM
Canadian Gashole
QC
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
While various solvents will attack many plastics, bags are usually made from polyethylene which is very resistant to virtually all solvents. Therefore it cannot be removed with MEK, acetone, lacquer thinner, etc.
Try some of the other suggestions.
Wayne
Don't get caught dead, sitting on your seat belt.
08-16-2007, 01:06 PM
CA
Just tell people it's the skin of the your last passenger. Seriously it will disapear, just don't scrape too hard with the abraisives and when using them you need something to lubricate the process as mentioned, wd40, water, solvent, soap and water.
John
08-17-2007, 09:26 AM
GA
Cobra Make, Engine: SPF #821,Southern Automotive 427 Side Oiler w/2x4
Flitz and elbow grease is what I used. Ill try the ice cube or oven cleaner next time
Alex
08-17-2007, 11:27 AM
AZ
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
I tried that on jet coat Superformance pipes to remove the nylon from some dude's gym pants. It made a mess for me and never looked the same. I tried buffing it out to look a bit better, but always came back looking weird.
I bought new side pipes.
08-17-2007, 12:29 PM
ca
thanks......you are great........unfortunately.......we tried....messed up worse.....now will hve to take it to ceramic coating place.......for new coating! bummer.....but life could be worse.........really worse!
fred z
08-17-2007, 12:32 PM
ca
sorry dbl post
08-17-2007, 01:09 PM
wa
fred z
What did you try that made it worse?
08-17-2007, 01:48 PM
ca
my friend tried....easy off.....obviously, it is not the answer....but next time i will be prepared. I am going to ask the guys that do the ceramic coating....what is THEIR answer.
will keep you posted.
fredz
08-17-2007, 02:03 PM
wa
I have been going through the paperwork I received with the car and one of the items is from Performance Coatings where the original owner had the pipes coated.
Here is their recommendation.
"Most stains can be removed with very hot water or non-abrasive aluminum polish (Wenol, Mothers, Never Dull, Zep 5 Star). Wash your headers with soap and water. DO NOT use any harsh alkaline (like Castrol Super Clean) or acid cleaners or chemicals on your headers, it will damage your finish!! Once damaged, it must be completely recoated."
Sorry I did not read and post this sooner.
08-17-2007, 04:28 PM
AZ
I tried aluminum polish too, first gentle hand rub, then buffer after hand rub didn't work. It just never went back to looking as good as new again.
