Old 08-23-2007, 12:04 PM
Jimi G's Avatar
Originally Posted by Roscoe
Real men don't need instruction!
Roscoe
My favorite type of customer,
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 08-23-2007, 01:33 PM
Wayne Maybury's Avatar
Canadian Gashole
Roscoe
Roscoe, normally I would agree with you 100% but in this case, I am very glad that I did read and follow the instructions.
Wayne
Old 08-23-2007, 01:38 PM
Roscoe's Avatar
Wayne and Jimi,
While I refuse to stop and ask directions, when I installed my bearing I read the instuction about three times and had Tilton on the phone while I installed the bearing. I guess I called them three or four times, checking and double checking, before I felt it was in right.
Roscoe
Roscoe
Old 08-23-2007, 02:09 PM
Jamo's Avatar
Super Moderator
Here's the thing...they are great when they work (good pedal feel, packaging, etc.), and the vast majority last as long as you need. The problem comes if and when you end up with a problem out in the middle of phuking nowhere (a description of 80% of the land west of the Rockies).
With an external slave, you dig out the seal kit you were smart enough to carry with you or get to the nearest Napa, Pep Boys, etc. and you fix the sumb!tch, fill it and bleed it and get on your merry phuking way.
With an internal...pull out your AAA card and wait a few hours for the truck and then sit on the bench seat next to the tow truck driver and listen to his view of the world while he spits chew juice out the window (when his aim's good), and then figure out how to get your beast home so you can: 1) pull the motor and trans out, or 2) pull your interior and trans out...and then redo the little basturd all over again.
Sh!t WILL fail on these basturds (notwithstanding Hal and his Cobra from another planet)...the issue is how easy it will be to fix and get back on the road.
KISS
Jamo
Old 08-23-2007, 03:12 PM
Roscoe's Avatar
Are you trying to put a Malocchio on me????
Roscoe
Roscoe
Old 08-23-2007, 03:18 PM
Jamo's Avatar
Super Moderator
Hehehe...
Here's looking at you, kid.
Jamo
Old 08-23-2007, 03:54 PM
RedCSX1's Avatar
I saw way too many fail before I purchased my Shelby and made the decision to go with the external. As Jamo pointed out. Its a matter of how easy and quickly you can make a repair when it does fail.
Morgan LeBlanc
Fresno CA
Old 08-23-2007, 04:07 PM
54h 54h is offline
Cobra Make, Engine: F5 SP-2
BDR561,
I have a new in box QT bellhousing complete with a slave cylinder mounted and billet throwout arm. Takes a standard ford throw out bearing. These work great. let me know if you are interested.
Dean
Old 08-23-2007, 05:07 PM
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
54H
I have all the items QT, slave, etc... What bracket was used to mount the slave? What does your billet arm look like?
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
Old 08-23-2007, 05:21 PM
Ibr8k4vetts's Avatar
KISS
Are you telling me YOU can't drive with out clutch
Mike Z
Old 08-23-2007, 07:36 PM
JayBar's Avatar
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
Cashburn,
You have posted the picture of your bracket before, but it is really to dark to get a "feel" for what it is connected to etc. Could you take a new picture and post it? BTW how much do you want for a bracket?
JayB
Jupiter, FL
Old 08-23-2007, 07:45 PM
Cobra Make, Engine: kirkham 427 stroker
dont waste your time and clutchs oh and taking your trans out 6 times wasnt fun either
  #33 (permalink)
Old 08-23-2007, 07:47 PM
external slave all the way!
  #34 (permalink)
Old 08-24-2007, 05:15 AM
Canadian Gashole
My feelings, exactly. A clutch does make driving easier (especially in stop and go traffic) but it isn't "assolutely" necessary.
Wayne
  #35 (permalink)
Old 08-24-2007, 09:48 AM
Jamo's Avatar
Super Moderator
My first "car" in high school was a half-ton 49 Plymouth flatbed truck that I would load empties, tomatos or grapes on the back of on the way home from school. Took Cheerleader on our first date in that thing.
I really didn't know about them new fangled things called clutches...seemed like they were for sissys.
Bite me for doubting me.
Jamo
  #36 (permalink)
Old 08-24-2007, 09:58 AM
The EXTERNAL slave on my ERA failed some time ago, on the road away from home IN TOWN! Dang stop lights, I made a bunch of 'right turns' because stopping was a serious problem.
Shifted without the clutch on the way home, piece of cake, like a hot knife through butter once your rolling.
  #37 (permalink)
Old 08-25-2007, 03:36 PM
David Kirkham's Avatar
Original Shelby Owner
IMHO,
The hydraulic throw out bearing is right next to Osama Bin Laden on my list of my most favorite things in life. We have changed 5 of them out this year already. I am pretty sure we installed them correctly. I am very sure the swollen o-rings (ALMOST TWICE THEIR NORMAL SIZE) was not correct. Yes, we even used the "recommended" brake fluid. Someone put the wrong formula rubber in the o-rings. We called and they "fixed" that problem...yes, and I pulled another 4 OUT after the fix!!!
They are an abomination and I wouldn't defile the ocean by giving them the "deep 6" test.
There, now you know how I feel. I think Jamo's opinion of them is only slightly worse than mine.
  #38 (permalink)
Old 08-25-2007, 03:58 PM
jwd's Avatar
jwd jwd is offline
David, I wish you and Jamo would not sugar-coat it. Tell us how you REALLY feel.
  #39 (permalink)
Old 08-25-2007, 06:03 PM
I could have gotten more descriptive
You should have heard Jamo when I told him we had developed a NEW hydraulic throw out bearing that I guaranteed would not leak. Jamo told me to put it in unmentionable places that look too much like his avatar...
I repented and developed an external system! Haven't had to pull one out since.
  #40 (permalink)
Old 08-25-2007, 06:23 PM
Naumoff's Avatar
But David you love them in 2005.
Done with McLeod
I like mine because it is working fine. I do agree that if there is a problem with it, pulling the tranny aint fun and if you don't get it right to have to pull it right out again scores very high on the sucko meter.
When I build another car it will have a slave.
