November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 09-24-2007, 03:20 PM
Default hood prop rod help
I would like to know where I can find a polished stainless or chrome plated hood prop rod ? I have called several of the "cobra parts companies" but nobody seems to have much. I would like one that "locks in" in the open and closed positions. I have a B&B/California Concepts car which I bought used. If anyone out there can help I would sure appreciate it.
Barry
Old 09-24-2007, 07:50 PM
Dwight's Avatar
Smile
Make one out of stainless. How do you want it to lock in?
I use a large and one small rubber O ring to hold the prop rod in place. They keep the wind from blowing the hood down. I saw one at the London Cobra show last June. It's a two dollar fix. I don't have a pic but will try to remember to take one tomorrow.
Dwight
Old 09-24-2007, 10:02 PM
If you can get a picture, that would be great. I would like it to lock in rather than depend on gravity. How did you hinge it in the engine compartment? Did you use a solid rod or tubing?
Barry
Old 09-25-2007, 04:34 PM
Dwight's Avatar
Smile
two rubber O rings and one aluminum screw from a storm window.
Dwight
Old 09-25-2007, 09:10 PM
Nice and simple, even I can do that. Thanks for the pictures, they sure make the fix clear. I've got a prop rod that came with my car from the previous owner but it looks like a kid made it. I think i'll start from scratch and use your connector.
Thanks again,
Barry
Old 09-26-2007, 09:15 AM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
I just ran across a setup that may be of help to you:
http://www.hydeproducts.net/
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 09-26-2007, 10:08 AM
Hank Steckel's Avatar
Cobra Make, Engine: BDR #258, British Racing Green/Silver Stripes, Gray Int., 351W, T5
Backdraft uses a stainless steel rod on their cars with a small plate on the hood which locks it in place when the hood is open. You might contact Reg Dodd at Backdraft. It won't be a two dollar fix, but it will look nice and they work.
Hank
I never make mistakes. I thought I did once, but I was wrong.
