| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
09-30-2007, 04:10 PM
NY
Cobra Make, Engine: streetbeast kit
Who is the biggest ?
HI guys we are trying to figure out if we will fit.
my son is 6'4" 212 lb
i am 6'4' and a lot larger.(old fat guy).
but now i am on a Cobra diet. i fugure by the time we finish a car
i will fit.
Who is the biggest cobra owner??
09-30-2007, 04:32 PM
FL
Cobra Make, Engine: EverettMorrison,408W,Jag rear, toploader
Not the biggest
I'm certainly not the biggest, but I'm 6'4 and at one time weighted 280. I was able to ride comfortably and I have a 90" wheelbase cobra. I have a 16" steering wheel and a reduced hight seat cushion. Go for it.
09-30-2007, 05:07 PM
Beam Me Up Scottie
MA
I'm only 5 ft 18 inches and weigh 22 stones.
There is someone on this site that is 6 ft 9".
Warren
09-30-2007, 05:12 PM
wa
I'm 4' 20", and weight 1/8 ton.
10-01-2007, 06:26 AM
Backdraft Racing Dealer
CT
You're just a puppy  Seriously your size would not be a deal breaker for the Backdraft. Additional interior space over others and we have a wide and wider seat option that goes a long way.
Where in NY?
10-01-2007, 07:31 AM
NC
Cobra Make, Engine: Superformance, Roush 402IR
I'm 6'4" and 260 or so. No problem in my superformance with a slight seat modification - we took half the foam from the seat.
10-01-2007, 08:28 AM
AZ.
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
You are all just pups. We have an owner (ex ball player) 6' 8" and a bit over 325 with a shoe size of 15. He did add a quick release or removable 15" steering wheel as the final touch.
10-01-2007, 09:20 AM
OH
Cobra Make, Engine: CSX4xxx, Alum. Shelby 427 w/ Webers,
I just extented the peddles forward and I fit at 6'5, 225lbs. It all depends on where your height is (legs v. body).
Sit in a number of different Cobra's and find the one you fit in. None are really comfortable, but find what you like.
Good luck
Jon
10-01-2007, 10:42 AM
Cobra Make, Engine: Midstates,SBF 357
My son drives mine and he is 6'7" and weight is about 230.
10-01-2007, 11:06 AM
CA
Cobra Make, Engine: FFR MKIII, FMS BOSS 302 "B" cam
I'm 6'6", 280 lbs with size 15 shoe.
I "tried on" over 20 different cobras and couldn't work the pedals in all but one. I had the bug bad though so even though I could only fit in one out of 20 I sat in I ordered one anyway.
I used Wilwood pedals which are adjustable. That added 2" of legroom. I also have 17" Kirkey Intermediates which I cut into low-backs and are being mounted to the floor. This add 2" more legroom and my eye site is below the top of the windshield. I also have a quick-release 14" wheel, which help as well. Last thing I did was widen the foot box using a pre-cut piece from an after market vendor. I can work the pedals in sneakers now, instead of having to use driving shoes or going barefoot.
HTH,
10-01-2007, 01:15 PM
Ca
Cobra Make, Engine: B&B 351/402 Fi roller everything
6'2" 240lbs. fit nice in my B&B.
the older i get the faster i was.
10-01-2007, 06:22 PM
NY
redss454, sent you a PM.
Dave
10-02-2007, 09:16 AM
TX
Bob Evans, who used to post here quite often, is around 7' 1" or 7' 2" and 280 or so pounds. Although I think he sold it recently he owned a Unique 289 FIA for several years. He would have to fill you in on the details but after some mods he fit in it quite well. Probably better than his current Z06 'Vette, which has the driver's seat removed--he sits on foam padding on the floor.
10-02-2007, 11:07 AM
NY
Cobra Make, Engine: Contemporary classics 3041,sbc 350(have no fear ford guys for there is a FE 428 in the garage waiting to be rebuilt & installed) but for now she is a driver while other projects take precidence.
I'm 5'-7" , 175 and fit just fine....
THOUGHT FOR THE DAY: There is more money being spent on breast implants and Viagra than on Alzheimer's research. This means that by 2030, there should be a large elderly population with perky boobs and huge erections and absolutely no recollection of what to do with them.
