| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
10-01-2007, 07:29 PM
ca
Cobra Make, Engine: classic roadster,408cu
Plans for the quick jack?
Does anyone have plans or dimensions for the quick jack??
10-02-2007, 11:16 PM
CA
Cobra Make, Engine: HI-TECH 289 FIA
Do you have a fax available?
fiaroadster
10-03-2007, 03:04 AM
MD
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Hey Rick, I have a fax.
410-535-1894
Then I can post them.
10-03-2007, 02:24 PM
CA
On its way.
fiaroadster
10-03-2007, 06:28 PM
ca
got fax?
Thanks I got fax , 650 261 1689 thanks again!!
02-20-2012, 12:26 AM
IL
Cobra Make, Engine: ERA 454 S.O.
Hey guys, is there anyway I can get prints or sketches? I have access to a laser. Thank's
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
02-20-2012, 02:40 AM
TR
Cobra Make, Engine: scratch built 289 eclectic mix of fia/ussrc/early comp
i've got hires picture of front & rear quickjacks, but i'm not sure about shape.
i can share if anybody want.
my plan is to lazer cut from stainles-ssteel for my scratch builds.
02-20-2012, 06:49 AM
Ca.
Note that the bolt pattern and hole diameter is different on some. I know the Classic Roadster is different than the standard. I have made my own from 1/4" stainless. I can share the solid model files if someone wants them but be sure to check your bolt spacing and hole diameter.
They are in SolidWorks but I can save them to pretty much any format that you need.
I made mine the same size front and rear but any shop that can laser them can change that with ease.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
02-20-2012, 07:20 AM
Cobra Make, Engine: Gardner Doulgas
I'm interested in the solidworks model :-)
can you send it in a email ?
thank you in advance.
Wouter
02-20-2012, 08:08 AM
TR
it would be great to compare your 3d model to my reference picture.
could you send me in iges format ?
02-20-2012, 12:39 PM
Ca.
You will have to PM me with your e-mail addresses. I do not believe I can attach anything to the e-mail from here on CC.
Terry
02-20-2012, 01:26 PM
TR
done that !
02-21-2012, 10:14 PM
IL
Solid works!!! My man. PM sent.
Thank you.
Jeff
Mark Donahue
02-22-2012, 07:25 AM
TX
Is there some place here on CC where we can share .pdf or .dxf files?
DRB GT40 MK1 red #49- sold
SPF 2063
02-22-2012, 09:02 AM
TR
hi
it's possible to open an ftp user at clubcobra.com to access public folder. it's up to brent.
regards
ozgur
03-01-2012, 03:17 PM
TR
Thank you Terry
I've flatten 3d IGES model using rhino3d and export as DXF for laser cutting.
I've used 5mm stainless steel.
Regards
Ozgur
Ozgur TAN
03-01-2012, 04:39 PM
Ca.
Great, glad that you could use and modify the file for your needs.
Terry
