Like Tree1Likes
Old 10-24-2007, 08:40 AM
Cobra Make, Engine: Hurricane Motosports
Default Drop base for oval air cleaner???
I am in the same boat as a lot of cobra owners are in. I have 351 block [408]using victor jr intake with 850 doublepumper . After machining down the base of filter housing and drilling for float adj. the thickest filter I can use is 2". I know I am sufficating my motor. I did a search on this sight... most of the threads are fairly old and was wondering if anyone has found a drop base for oval filters or any other recomendations. I know I can use this filter for show and a different filter for performance. My hood opening is 11" wide so I can't use a 14" round. I have herd conflicting arguments on edelbrock triangle filter and not a big fan of them but I want the performance that my eng. is capable of. Any options or suggestions would be greatly appreciated. Bermblaster
Old 10-24-2007, 08:59 AM
Cobra Make, Engine: KMP
I used one of these and had the base machined slightly to fit under my hood.
http://store.summitracing.com/partde...5&autoview=sku
Lew
I'm no expert.
Old 10-24-2007, 09:03 AM
Banned
Berm, I did the same mods as you on my 12" oval and am getting ready to do the same to my 15". The SPFs might have a little more clearance, as I'm running a 2.5" filter and still had some clearance. There is another SPF owner running a stout BB that used an 1/8" end mill to cut the base. He then welded in 3/4" alum strip stock to drop it. Now runs a larger filter without any clearance issues and it looks great. I may do the same in good time, but for now just eliminating that 3/4" 'collar' and drilling clearance holes for the float adj. nuts. is a great mod and it actually looks cleaner, too.
For those considering this, Pep Boys sells a valve cover grommet set from Spectrum (Spectre?). It has two 1.25" grommets, one for use with a PCV valve and the other for a breather. Buy two and use the PCV grommets. Use a 1.25" hole saw and some cutting oil. Measure three times and cut once.
-Dean
Old 10-24-2007, 09:57 AM
thudmaster's Avatar
Regularly Offensive
Cobra Make, Engine: spf
I found my dropped air cleaner at my friends machine shop. He is a circle track racer. Most of them have have the kind of air cleaner you are looking for.
Ed
Too close for missles, switching to guns.........
Old 10-24-2007, 12:46 PM
Frank Messina's Avatar
I can't even count the number of combinations I've tried, and filters I've wrecked trying to get something that fits and flows. I even went so far as to pitch the idea of a drop base oval to one of the aftermarket companies I'm close to but no dice. Anyway I finally wound up with a 14" Moroso drop base, 14" X 2.25" K & N element and a plain chrome lid from Ford Racing. This is the only setup that will work on my car. I originally had a 3" element in there but wore a spot through the paint where the scoop blends into the hood when the engine torqued over (Energy Susp motor mounts). Like I said this works for me as I have a Holley HP carb, but I'm not too sure how it would be with a carb that has a choke tower. I really wanted a cool oval like Dean has, and in fact bought one, but the hood wouldn't close so that dream ended quick. I still think a mid size drop base oval with a 2.5" - 3" filter element would be the hot setup for a single carb. Maybe if we got a show of hands we could get somebody to build one.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
Old 10-24-2007, 01:05 PM
Cobra Make, Engine: SPF #1019
I've got one of these and I like it! They are available from http://www.universalspinners.com/autoparts.html
Old 10-24-2007, 01:07 PM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default Go to Ital-Cobra pictures in gallery
He came up with a novel cure. Looks like very similar setup to yours.
Old 10-24-2007, 01:44 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
I have a edelbrock FI. on my 351(402)B&B cobra.It has the triangular edelbrock filter turned sideways .It works but I hate the way it looks.I really like the summit air cleaner but even if i cut the 1/2 inch off the bottom i'm still 1/4 too tall.I 'm thinking of just getting a 1/2" taller hood scoop and the summit oval air cleaner.That is when i can find 400 more clams.
the older i get the faster i was.
Old 10-24-2007, 04:08 PM
Banned
Originally Posted by Murphy
He (Ital-Cobra) came up with a novel cure.
His was for EFI. Different but clean looking.
I got more out of his 'other' pics though.
Old 10-24-2007, 06:30 PM
Madmiles442's Avatar
Originally Posted by Frank Messina
......... Maybe if we got a show of hands we could get somebody to build one.
Frank
I'd be in for a drop base on the standard finned Cobra air cleaner!
Just tell me where to send the check!
MadMiles442
Old 10-25-2007, 03:57 AM
I want to thank everyone for their input. I am going to try and fab a drop base out of sheet metal. I will post pics of my progres and how much of a gain I can come up with. Thanks again!!! Berm
Old 10-25-2007, 05:12 AM
Cashburn's Avatar
Backdraft Racing Dealer
We've started this project in the past. The real limitation starts to become the linkage on the carb. With a round drop base you can get around this, but an oval is close to the carb on the sides (where the linkages are) and far on the ends (where nothing is).
We have trimmed the lip on the bases and also dimpled for the top bolts of the carbs with limited success in getting some more room.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 10-25-2007, 06:14 AM
JRoss's Avatar
Cobra Make, Engine: Lone Star Classics #89 Keith Craft Genesis 427 so, stroked to 482, 649 hp. Sabre GT 40 #16 351W stroked to 408, 527hp, TWM stack injection, Fast XFI, G50/50.
Berm,
Here is an example of what you are looking for. A buddy of mine made it and before you ask I have tried and cant get him to make any more. The carb linkage did need to be trimmed to fit.
good luck making yours.
BornWestUSA likes this.
Old 10-25-2007, 06:25 AM
That is similar to what I did. I used 2 filter bases for the top and carb base, from Cobranda. Mine doesn't drop much, but fits (just barely) under the hood.
Old 10-25-2007, 07:42 AM
Cobra Make, Engine: Former Everett-Morrison,428SCJ
What does the low air cleaner top do to airflow?? Any dyno results with, and without the dropped filter??
-Jon
Old 10-25-2007, 07:47 AM
John that is very similar to what I had in mind. I am not set up to tig weld so I will attempt with some mild steel sheetmetal that can easily be mig welded. Thanks a million for the pic. It sure looks like you gained a whole inch with the drop. Are you able to get a 3" element to fit? Thanks again!!!! Berm
Old 10-25-2007, 09:35 AM
JRoss's Avatar
Yep gained 1 1/4 inch and the 3 inch K&N filter fits great under the hood
Old 10-25-2007, 09:42 AM
good news. I will post progress later. Thanks
Old 10-25-2007, 10:27 AM
Wayne Maybury's Avatar
Canadian Gashole
I have to also do this (make a dropped bottom oval filter). I presently have one of those small chrome S & H filters on mine and while it was not dynoed, my friend did put it on the flow bench. I can't remember the exact results (they are posted somewhere here on CC) but the filter reduced the flow of my 750 Holley by 30 to 40%.
Wayne
Old 10-25-2007, 11:22 AM
Banned
Period correct but flow poorly.
I'm going to experiment with my 12" oval air cleaner and if I can do a clean drop on the circumference, then I might attempt it on the 15" oval unit that I just purchased and dropped off at the machinist yesterday (to mill off the carb riser).
There is a market for this sort of thing, but it's limited and you really need to have a carb in which the complete air horn has been milled flat (to keep the air flow). Having a choke tower in the way will only hurt performance.
-Dean
