Old 10-28-2007, 09:03 PM
Garage10's Avatar
Cobra Make, Engine: west Coast Cobra FRP 460, Tremec 5 sp, Ford 9" rear
Default Does your bellhousing hang below frame ?
I am wondering how many cars out there have their bellhousing hanging below the frame and whether you did anything about it like building a skid plate for it ? Any pictures ? Mine hangs below frame and scares the heck out of me ?
Thanks
Brent
Old 10-28-2007, 09:13 PM
GlynMeek's Avatar
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Mine hangs below, and I think most do...I have an oil pan extension that is actually lower than the bellhousing though, so I would rip that off before I did the bellhousing....
How far below does it hang? What is the clearance from the bottom of the bellhousing to the ground?
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
Old 10-28-2007, 09:27 PM
Power Surge's Avatar
Using the Lakewood bell, yes. Most people trim the bottom to be even with the frame.
Sal Mennella
Old 10-28-2007, 09:30 PM
Senior ClubCobra Member
Talking
The scattershield on mine is well below the frame. With the 3/4" flange on a scattershield it's even worse than a bell housing. It makes a great skid plate , sending off showers of sparks evertime I bottom out on a speed bump.
I just avoid the speed bumps.
Old 10-29-2007, 02:39 AM
427 S/O's Avatar
Like Sal said and I went a little further...check my pics....
Perry
Old 10-29-2007, 06:14 AM
mickmate's Avatar
My Lakewood is dead level with the frame now, the sticker that warned not to cut weld or grind on it fell off somehow........must have been the warmth from the plasma cutter
mickmate
http://www.actoncustom.com/
Old 10-29-2007, 06:19 AM
mickmate's Avatar
This is all you'll need to know http://www.kirkhammotorsports.com/ma...ld/index.shtml
mickmate
Old 10-29-2007, 07:43 AM
Bryan Wilson's Avatar
Cobra Make, Engine: Real: Southern Roadcraft, SRV8, 351W stroker
Default low bell housing
maybe I Should have a skid plate
COB-66 Young at heart old fart.
Don't drive faster than your guardian angel can fly.
If it doesn't matter what gear your in you have enough torque.
VK3KDN
Old 10-29-2007, 08:29 AM
Banned
Default Yes, it does.
Trimmed to maximize clearance (note the pan will hit before the McLeod bellhousing will)
Old 10-29-2007, 05:27 PM
djseed's Avatar
30 Year Wait is Over
Cobra Make, Engine: SPF 1630 '70 429 SCJ / 501
Default BB Ford & SPF With Lakewood Bellhousing
This is the photo before I trimmed the bellhousing.
It now is just slightly lower than the oil pan.
David J. Seed
Q: What makes a good racer?
A: Size 14 shoe, size 2 hat.
Buddy Baker, NASCAR Hero
Old 10-29-2007, 05:51 PM
jwd's Avatar
jwd jwd is offline
Pan and bellhousing are protected by the frame. I fear no speed bump.
Old 10-29-2007, 06:27 PM
CSX 4027's Avatar
Cobra Make, Engine: Sold 3047 & 3002 in 2012
[quote=Bryan Wilson]maybe I Should have a skid plate
Nah, Just airbags for those abrupt stops
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
Old 10-29-2007, 10:54 PM
alpace@pacificp's Avatar
Cobra Make, Engine: Kirkham #492/ 427/482 Keith Craft. Simple, Clean.
Spoke with Joe Wight of Kirkham regarding this matter. They cut excess material from bottom thereby removing the 'danger'/concern.
Old 10-30-2007, 01:18 AM
Cobra Make, Engine: Superformance Brock Coupe
Another solution is to run a smaller diameter flywheel with a twin plate clutch (to increase the friction area) and use a correspondingly smaller bellhousing. Tilton makes these. Very nicely engineered. You can decrease the clearance under the engine by going dry sump. Ain't cheap, but speed never is... :0) Badger
Old 10-31-2007, 12:26 AM
Cobra Make, Engine: Hurricane Motosports
Just snagged my lakewood on Saturday on a raised manhole cover at a chevron gas station. Almost knocked my tooth fillings loose . This will be a definate mod this winter. Thanks for the pics of trimmed bellhousing. Berm
Old 10-31-2007, 12:39 AM
Cobra Make, Engine: spf, stroked 460
i also had my bellhousing cut off at house of cobras when i purchased my spf. I didn't know about it until they asked me about my driveway.
Old 10-31-2007, 05:28 AM
Default Bell housing hanging down
Yes mine hangs down and has been hit a couple of times only running the 17" wheel combo. The 15" wheel where OK. They have in the ERA manual about where to cut the bottom of the bell housing. With racing the car I don't think this is a good idea, (This is my own opinion) I want to keep that whole assembly of clutch and flywheel in that blow proof housing. Both flywheel and clutch are SFI but things still break. If you keep your car,ERA with a 5" ground clearance on 15" tires you should be just fine. For a high driveway, drive in on a angle not straight and slow. If you hit, you either need a new driveway or tell the town to fix the angle problem. Cuttuing the bottom of the bellhousing may make the bellhousing unsafe or illegal if you are racing at some of the roadraces like SAAC meets and some track. 1 guy was question at the VIR track last year. The warranty is void with any modifing of this part and the SFI sticker could get removed if push comes to shove. You are also to have ALL the holes with bolts,nuts and washer, grade 5 or better. I don't have every hole this way. I also don't spin my motors at 8,000 rpm either. Rick L.
Old 10-31-2007, 05:27 PM
Garage10's Avatar
Hi guy's
Thanks for all the replies.
GlynMeek. My blastshield flange hangs 2 3/4" below frame. Not sure how far off ground as it's on jack stands right now. But, I think it's about 5".
427S/O That rub rail of your is not too bad an idea unless you hit something narrow dead on.
I am lucky my oil pan is above frame. I still think I may trim my flange a bit and build a skid plate so car can slide over things rather than catch lip and have abrupt stops or jars. I have an idea how I will do this but was hoping to see some others ideas.
Thanks
Brent
