November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-19-2007, 11:06 AM
Cobra Make, Engine: KMP
Default Clutch recommendations (FE/TKO)
I will be pulling my motor over the winter to replace a cracked oil pan. While it is out, I might as well make sure that I have the best clutch set-up as possible. I currently have a Ram 11" with a hydraulic TO bearing set up. My motor is a KC bulit Shelby BB putting out 630+ hp/tq connected to a TKO-600 with a .82 OD and a 3.31 rear.
What do folks recommend as the best clutch package for that combo? This is a street driven and street abused car. Not a racer, but certainly not pampered.
Anything else that I should tackle while the motor is out?
Thanks,
Lew
I'm no expert.
Old 11-19-2007, 11:31 AM
Clois Harlan's Avatar
Lew,
Check your area and see if any of the racers have clutches made for them. I had a Kevlar clutch built for my 427 FE and I could not be happier. Pulled it out last spring after a year of street driving and about 1000 miles on several road courses and it looked brand new. Cost was about $120.00.
Clois
"Let's roll"
"Be part of Something Good
Old 11-19-2007, 02:06 PM
undy's Avatar
Thanks,
I'm running a 600 HP 482" FE built by Keith too and I went with his clutch recommendation, a Ram long style pressure plate w/a sintered iron disc. It's very streetable and has never slipped. My driving habits are similar to yours also. I'm running Mickey Thompson 315/35/17 ET Drag Radials on the car so I do load the clutch too. I'd make a phone call to Keith and see what he says..
Dave
Too many toys?? never!
Old 11-19-2007, 02:44 PM
Stentor's Avatar
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
Lew,
I have a setup that's similar to yours (engine, transmission). I am using a McLeod Street Twin, and have been very pleased with it.
Good luck.
Stentor
Old 11-19-2007, 04:05 PM
Jimi G's Avatar
Originally Posted by Stentor
Lew,
Good luck.
Stentor
I love the dual disks, they are the smoothest clutch and hold about 900hp, they have a real soft pedal too. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 11-19-2007, 07:55 PM
Cobra Make, Engine: KMP329 w/KC489 Shelby
Lew,
First of all, you don't need to pull the engine to change the pan unless you just want to pull the engine. I had to pull my pan to change my gasket, which I recommend changing if you have one of the piece of crap cork gaskets. The fiber ones seem to work well. I have the McLeod 12in clutch and pressure plate. I'm very happy with both.
