02-15-2008, 11:48 AM
Beam Me Up Scottie
MA
The only way I've found to get to those clubs is via the HOME page and then select FORUMS and then scroll down to the clubs.
Warren
02-15-2008, 11:50 AM
Beam Me Up Scottie
MA
Originally Posted by Ron61
Warren,
I don't ever go to that page but I just tried it and I don't have to scroll down. Maybe try setting your resolution a little higher.
Sorry Ron, I ain't going to change my screen resolution.
Warren
02-15-2008, 11:57 AM
Warren,
Here is my Home Page at the default resolution.
02-15-2008, 02:57 PM
Beam Me Up Scottie
MA
Warren
02-16-2008, 05:10 AM
Your mouse is sick. Replace it with a turtle.
Nothing on mind vanishes when I scroll down. Of course I am not using IE 7. Just the old standard IR 6 that works.
02-16-2008, 08:52 AM
Administrator
Wa
The script to make that thing work is ancient. With the software updates, something went a bit wrong. It used to be that the menu would float and remain visible at the top of the page at all times. A couple years ago, that stopped working and now it won't work at all in some areas of the forum.
I'll see if I can find another script that will work.
02-16-2008, 11:11 AM
Beam Me Up Scottie
MA
Put that LAST on your list of priorities.
Warren
02-18-2008, 06:09 PM
Cobra Make, Engine: Superformance 460 SVO
PHP has encountered an Access Violation at 028AAA08
02-23-2008, 07:42 PM
I just got this one:
PHP has encountered an Unhandled Exception Code -2147483645 at 028B30E1
MadMiles442
03-02-2008, 03:43 PM
Brent or Ron - Wanted to give you a heads up that I'm not seeing the option to IM. I went into my folder and it appeared as though my mailbox was full, so I cleared out all of the IMs in my folders. I don't see the link on the "quick links" either.
Thanks.
Doug
03-02-2008, 06:46 PM
PHP has encountered an Access Violation at 03363770
03-02-2008, 06:52 PM
Beam Me Up Scottie
MA
Warren
03-02-2008, 08:01 PM
Ca.
Looks like in the welcome block on the upper right side right above quick links and log out is missing PM information. When I try to even look up my PM information it says that the page cant be found.
Terry
03-03-2008, 01:54 AM
Terry,
It is working for me this morning. I ran into a couple of odd things yesterday that failed but figured Brent might be working on the servers. I just waited a while and they started working again. My signature line doesn't' work but I can take that out as it isn't important enough to have him worry about it.
03-03-2008, 06:00 AM
Ca.
Ron,
It is working this morning for me also
Thank you, Terry
03-03-2008, 07:32 AM
PM is working for me again as well.
Doug
03-05-2008, 05:57 PM
I am unable to see the current poll... the poll box is filled with the following text:
The block type Latest Poll
doesn't seem to exist.
Please check your
includes/blocks/poll script.
Anyone else having problem with the poll?
2011 TCC President
JSHEL1 on the Web
03-05-2008, 06:10 PM
Please check your
Thanks...that is a known problem. The panel that is to display the latest poll is misconfigured.
It'll get fixed.
03-05-2008, 06:19 PM
sorry to report a known problem... I should have read through the whole thread.
2011 TCC President
JSHEL1 on the Web
03-05-2008, 06:52 PM
No problem, John...good to keep hearing whatever glitches are seen by our users. Thanks.
