Old 04-02-2008, 10:06 AM
MEATMASTER's Avatar
Cobra Make, Engine: Johnsonville, 8-pack $4.27
That won't be necessary RonNichols. Just take photos of the procedure so we can better visualize it and post when it's all over.
Thanks.
MEATMASTER v2.0
Smoke the meat, only the meat and nothing but the meat... so help me Weber
Old 04-02-2008, 10:27 AM
mr. oz's Avatar
Cobra Make, Engine: spf 1689/462 SB barely runs
Originally Posted by RonNichols View Post
Better late than never, but I've used several pairs of Classic Chambered's in the past several months. I'm not sure of the muffler's you had on there, but on my SPF, the difference in sound is amazing. Factory mufflers are meant to pass local sound restrictions and cater to the general public. If you really want to get the most out of your motor, start with the exhaust. Otherwise, you just trying to exhale through a straw.
Dyno comparisons later this month.
Ronnie
I have a set of stock SPF sidepipes. Bring your car down and we will do a back to back dyno test with only changing the sidepipes.
BAMF462SB
Old 04-02-2008, 10:36 AM
RonNichols's Avatar
Cobra Make, Engine: SPF398/460ci/ 144hp of backfiring fury
Excellent Mr. Oz. Actually, I have a second pair that I was working on until yesterday. They will be cut up and redone with a weld on merge collector from Cone Engineering and a 3.5" louvered bore muffler. If you don't mind, and you have hot gloves, we can kill three birds with one stone.
Old 04-02-2008, 11:12 AM
mr. oz's Avatar
I have a side pipe swap down to about 35 minutes and I don't even unstrap the car from my dyno. I that you in your avatar? You are a fine looking man.
BAMF462SB
Old 04-02-2008, 11:55 AM
RonNichoIs's Avatar
Ok! I'll be there with bells and whistles on! nd yes, thank you. I do consider myself a very handsome gentleman.
If you are in the Detroit area, look me up cell 219-942-6311
Last edited by RonNichoIs; 04-02-2008 at 12:07 PM.. Reason: i needed to thank the compliment made to my good looks
Old 04-02-2008, 11:58 AM
RonNichols's Avatar
I knew you guys were being to nice to me to trust you. When I saw serious input from you guys, I figured it was only a matter of time before a trap was sprung.
Old 04-02-2008, 12:04 PM
mr. oz's Avatar
HUH ??????????????
BAMF462SB
Old 04-02-2008, 12:15 PM
uncltodd's Avatar
Cobra Make, Engine: BDR #139, Indigo blue, white stripes, KeithCraft 351W, 315 WHP, 17" Boyd Smoothies, dual roll bars, gunrack, assorted young females
I just want a way that I "practically" shut up the noise from blowby from my sidepipes.
That's it.
Backdraft Racing #139.
Eagles soar- but weasels don't get sucked into jet engines.
Old 04-02-2008, 12:53 PM
RonNichoIs's Avatar
When you say "blowby", are you mean the "fluttering" noise you might hear when letting off the throttle? If so, there may be a gasket leak somwhere in the system to the heads allowing air to be sucked into the exhaust. If you are talking about it just being too loud, then more muffling is needed, and not as easy to remedy without removal.
Old 04-02-2008, 01:39 PM
CHRIS DAMSCH's Avatar
Cobra Make, Engine: SPF 1454
I believe the earlier backdrafts have slip fits for the header to sidepipe connection. It could be the sound of the exhaust leaking there. A couple of our local guys with the backdrafts had flanges made up so the connection can be sealed.
CHRIS
Old 04-02-2008, 03:43 PM
RonNichoIs's Avatar
Thanks Chriss. Did those pipes make the noise that I think was being referring to?
Old 04-02-2008, 03:56 PM
CHANMADD's Avatar
I have the slip fit type at the collector. They work great at the track,just slip the sidepipe off and you've got an open header/collector,,and it sounds awesome!!
  #33 (permalink)
Old 04-03-2008, 07:20 AM
RonNichoIs's Avatar
Would it do the same thing if you really worked the connection hard to get a super tight fit? Maybe wrapped the pipe with something so it would hit the sides? Wouldn't a loose, sloppy fit rattle and flutter?
  #34 (permalink)
Old 04-03-2008, 05:23 PM
greg schroeder's Avatar
I have a set of stainless side pipes from www.buckshotracefab.com , 4,000 dollars , for my Superformance. They're ok, louder, more power. It took three jet sizes up to match the air fuel ratio of the Superformance side pipes.
Here's a large res. image.
http://www.clubcobra.com/photopost/d...rive_pic_3.jpg
off idle drag pass, DA 750ft.
  #35 (permalink)
Old 04-03-2008, 05:32 PM
Ronnie,
What noise are you referring too?
The new mufflers are pretty wicked sounding. We'll see how much I have to rejet very soon.
CHRIS
  #36 (permalink)
Old 04-03-2008, 06:47 PM
RonNichoIs's Avatar
Ronnie,
Chris,
You know...a fluttering noise...kinda like taking a blade of grass and blowing to make a noise....remember when you were a boy?
  #37 (permalink)
Old 04-04-2008, 03:05 PM
Cobra Make, Engine: SPF1002
Bombay Sapphire
  #38 (permalink)
Old 04-04-2008, 07:16 PM
RonNichoIs's Avatar
Originally Posted by RandallThomass View Post
Ronnie,
I demand that you stop tormenting Chris. Your aimless comments are unwarranted, and I demand that you stop this. NOW!
Or I'll send you to the hoosegow........<Awkward Silence> <crickets chirping>
Randall
Randall,
Lighten up a bit, I am merely trying to help a less experienced cobra owner to more fully enjoy the cobra experience. You have gone overboard and since we are close personal friends....please take your meds, you know what happens if you don't.....hoosegow???? Is that your special place? Now please lets keep this thread on topic.
Your buddy,
Ronni
  #39 (permalink)
Old 04-04-2008, 07:30 PM
RonNichols's Avatar
Sorry Ronni,
I literally am on meds right now. I had outpatient surgery today that didn't go to well, hence my absence from posting between 10-4. Its just frustrating to have posts go awry on other forums as well. Its been one of those cumulative days. At least my only shotgun is a youth version so my toe doesn't fit well in the trigger guard.
Ooops,
R
  #40 (permalink)
Old 04-15-2008, 08:27 PM
Rare Iron's Avatar
Originally Posted by carmine View Post
Wait till your classic chambered side pipes start to rattle. Mine did after one season and still waiting for my return call from Eric at Performance Engineering for there fix on there warrantied side pipes. Its been about 4 months now.
Carmine, who is Performance Engineering? They are not one of my dealers, & those aren't my mufflers you are talking about. No complaints to date.
-Eric S.
Manufacturer of COBRAPACK Mufflers
