February 2026
Old 05-23-2008, 06:02 PM
Silverback51's Avatar
Default Need Some Help
I have done a search and was not able to find what I need. Maybe I just missed it, so here goes.
My SPF currently has Goodyear GT II's on it. 255/60-15 on the front, and 275/60-15's on the rear.
My ride height to the center of the wheel wells to the ground are 26.75 in the front, and 25.5 in the rear.
I ordered some Goodyear Billboards and they will be here next week. I know that I will have clearance problems in the rear, as the 275's have less than 1/2 inch space between the tire and body.
The current rear tires have a 27.9 inch diameter. The new BB's have a 26.7 diameter. This would give me a ride height of 24.9 inches. I have not seen anyone running that low that I could find.
Now to my question. For those that are running the Goodyear Billboards on their SPF, what is your ride height? Also, on your upper rear shock mount, what 2 holes is the bracket bolted to? If I remember right, for a stock SPF they utilize the bottom two holes. Mine is bolted to the center two holes. I think I will have to change this, but don't want to do it if it's not necessary.
And yes, I know I will have to have it aligned after all these changes.
Any input will be greatly appreciated.
Old 05-23-2008, 06:45 PM
392cobra's Avatar
6th Generation Texan
John,
I greatly admire your avatar.
Old 05-23-2008, 06:52 PM
Originally Posted by 392cobra View Post
John,
Why thank you. I figured it was time to put one up.
Old 05-25-2008, 09:26 PM
Guess I will give it a bump to see if anyone responses after returning from a long weekend.
Old 05-25-2008, 09:58 PM
Rwillia4's Avatar
I don't have anything to add to the topic but I do like the avatars so far!!
Old 05-26-2008, 03:56 PM
PANAVIA's Avatar
What exactly are the "Good Year Billboards" are they GT's or repro Blue dots >?
Old 05-26-2008, 04:27 PM
Stentor's Avatar
Default Goodyear Billboards
Here you go...
