November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-27-2008, 03:36 PM
Greg Curtis's Avatar
Cobra Make, Engine: spf1266 460,TKO,titanium/black stripes
Default Lowering the Ride Height
You guys using any special spanner wrench on your coilovers to lower your ride height or are you using the old punch and hammer trick. I have an SPF that has a height of about 27" to the lip of the fender and I want to go a tad lower because I think it looks too high.
Greg
SPF 1266 460/TKO
1971 Chevelle SS
1967 Pontiac GTO Ram Air
1962 Thunderbird Conv.
1991 Mustang GT Built
Old 05-27-2008, 05:01 PM
SF_SN888KE's Avatar
Cobra Make, Engine: Cutting Edge Replicas, 427 World block SBF, TWM Injection
Most measure from the bottom of the frame. Changing the ride height will effect handling. Just my $0.02
Ron; SF_SN888KE
Cutting Edge Replicas 427
Shell Valley Daytona #27
Old 05-27-2008, 05:08 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
On any Superformance MKIII, I believe the recommended ride height is 27" at the rear fender lip. Any lower, and you run the risk of bottoming out the shocks and that can cause undue stress on the shock mounting brackets.
Old 05-27-2008, 08:50 PM
JCoop's Avatar
Cobra Make, Engine: Superformance, FRP460 Big Block
I run 26.75 all around on my SPF (17" wheels) but I had to redo the alignment on all 4 wheels. Too much negative camber when I lowered it, requiring even more brute force to steer the beast. I don't have the bottoming out problem. 27" does make it look really high, especially with 15" wheels.
Use spanners available at Jegs or Summit.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
Old 05-28-2008, 01:52 PM
Cobra Make, Engine: Look-a-like cobra POS
Use a spanner wrench, available from any speed shop or catalog. I use Paragon.
B. Ewing
Old 05-28-2008, 01:57 PM
Cobra Make, Engine: KMP 498
On KMP 498, I just jack it up and turn the thing by hand.
Sanded Aluminum Finish? Because I Can!
