Old 06-19-2008, 03:03 AM
Mdman352's Avatar
Cobra Make, Engine: Contemporary-427 stroker
Default Shifter options
I have a top loader transmission and find the Mustang type shifter a pain (in the hand) to use. What are the options available? Thanks.
David
Old 06-19-2008, 04:38 AM
MrMagoo's Avatar
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
I have always liked what I had in my first car that had a toploader... a hurst shift handle with a ball knob. However, now I have a T-5 with a pro 5.0 shifter, and I am using a ford leather shift knob, and I really like it. When you are pulling back, like 3-4th, your fingers grip under the ledge in the front, and the padded leather feels good on your hand.
If I can see you, I'm too close
Old 06-19-2008, 06:44 AM
After 13 years of shifting with the non-functional 'T' lever gouging my hand, I had enough. Two weeks ago I removed the 'T', but retained the shift handle and original ball. It is a lot more comfortable now. Shoulda done it 12 1/2 years ago.
David
Old 06-19-2008, 12:54 PM
MrMagoo's Avatar
Yeah David, the first thing I did when I got my cobra was to get rid of that shift handle. Now, go one step further and get a Ford Motorsports leather shifter and you'll really be happy
Old 06-19-2008, 03:41 PM
scootter's Avatar
Cobra Make, Engine: SPF #1436 514
I like the Jordan shifter with the standard black handle. I also put in the Pro Shift.
Scott
http://www.secondstrike.com/SecondSt...danShifter.htm
Old 06-19-2008, 04:14 PM
BAD ASP's Avatar
Cobra Make, Engine: superformance,408 w with 93mm intercooled turbo
I am using the pro 5.0 and the cobra shift knob from finishline. It's comfortable and I did remove the t handle.
Old 06-20-2008, 02:38 AM
Mdman352's Avatar
Default Mr. Magoo
Which Hurst shifter??? What height and angle?? Thank you.
David
Old 06-20-2008, 04:17 AM
MrMagoo's Avatar
It's nine inches long with a 15 degree bend.*The nine inches is the straight line from the tip to the bottom cutting across the curve. It is bright chrome, says "HURST" on it in the classic manner, and is stamped "0015" on the bottom. The knob is a ball marked up for a standard 5 speed.
