Old 10-09-2008, 11:27 AM
Silverback51's Avatar
Originally Posted by tmareina View Post
I've got 2 660's on my 614 hp 428 with a tunnel wedge...it's awesome and no problems leaving the stop lights in a mild mannered disguise for those road dogs that want to cite you. Although how much of a disguise can you really hide behind. Also I get about 12mpg on the highway with my TKO in 5th gear when I don't get too foot heavy with the throtle. Response is excellent even at lower RPMs.
Tom
I'm assuming your 660's are the mechanical secondaries with the center squirters. That is what I have on my 460 and love them. The only thing I'm going to do over the Winter is to mill off the air horns. Should help out the air flow to the primaries.
Old 10-09-2008, 08:29 PM
davids2toys's Avatar
I did not think you could put a 460 in our cars, maybe just my car...lol. Hmmm, I wonder. I saw a nice 521 based on a 460 block, but I did not think it would fit!
Old 10-10-2008, 04:29 AM
Tony Aprile's Avatar
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
They fit !!! With two vacuum secondary 600's.
Old 10-10-2008, 04:45 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Not that I would want to show any age here, but:
(Max rpm X cubic inches)/3456 = max CFM at WOT.
Give it a try and add a few percent rounding the CFM up.
Just my $0.02 worth.
Old 10-10-2008, 09:03 AM
Very Very nice Tony, would you be able to pull the motor without removing the body?
Old 10-10-2008, 11:15 AM
dave...thats a good question !!!!
Old 10-10-2008, 11:30 AM
I run dual mechanical 600s. No problems. I had to jet down from the setup coming from the engine builder in addition to putting on K&Ns.
Old 10-10-2008, 12:10 PM
You can pull the motor, but not the heads if you have non-removable studs. You might be able to if you jack the motor up a couple inches, but I'm not sure.
Old 10-10-2008, 02:10 PM
Originally Posted by 69boss429 View Post
I have the same straight linkage on 2 715 vaccum secondary carbs I purchased from Carl's ford parts.
Said to be repops of carbs used on the early 427 dual quad setups.
Very smooth street performance.
Can you tell me where you got the air cleaner tops for your setup?
Still looking for those air cleaner tops,anybody have a source?
Old 10-10-2008, 02:27 PM
427 S/O's Avatar
69boss, I made them, got a water jet company to cut 4 wagon wheels, 2 from plastic and 2 from aluminum. Went online and bought 180 micron stainless steel wire mesh, you can cut it with regular scissors. Drilled,tapped 4 holes and done!. I need to do them over because the water jet guy cut them 7 1/2 instead of 8 inches.........
Perry
Old 10-10-2008, 03:13 PM
tmareina's Avatar
Cobra Make, Engine: Unique #9159 428 FE 614HP by FE Specialties
Silverback51
Thanks for the info on milling the air horns...I will look into that. And yes they are mechanical secondaries.
Tom
Old 10-11-2008, 04:39 AM
Thanks for the info,have you considered making multiple sets,I would be interested in some.
Thanks again,
Dave
  #33 (permalink)
Old 10-11-2008, 01:00 PM
427 S/O's Avatar
I might, a couple of other members ask as well. A retired ford engineer told me 'NO' available air cleaner is any good, as an example, he said look inside after a few hundred miles and you will find dirt!. I figured any dirt that can pass 180 microns will be easily digested with little harm. So far, so good, after 13K hard miles I still don't burn oil......
Since business is a little slow, I'll call the water jet guy next week........
Perry
  #34 (permalink)
Old 10-11-2008, 01:35 PM
I have a pair of the 600 CFM 1850 Holleys on a tunnel wedge set up. I'm on a quest to get them functioning as a pair of carbs designed for dual carb appication. Thruth , I can't remember ever getting into it long enough to notice if the secondaries ever opened.
I have the Mallory HyVI and have rev limmiter programed for 6,000 to keep everyting from going south. I still like those flow through aircleaner tops.
Mike H
  #35 (permalink)
Old 10-11-2008, 02:04 PM
decooney's Avatar
Default Tried a few different dual setups, interesting results
In a local circle of friends and different cars, we did dual 450s on a 331 stroker Cobra which worked very well with progressive linkage, then dual 450s on a FE 390 which worked okay (could have been better) as it just did not have the same zip as it did with the single HP 750 did, then a set of brand new and finely tuned dual 550s on my friends original R-Code 427 Galaxy. He really likes this setup a lot, with factory pluged up type exhaust and original exhaust manifolds, these 550s do really well on his original 427. On another guys car he had a set of well tuned 600s in a Cobra. I'm just thinking back on all of these configurations trying different stuff and who was happiest. Knowing thisnow, If I were to do a dual setup on my FE it would most definitely be a well tuned/jetted-down/flowed pair of 600s (or so) Holley's, followed by lots of messing and fine tuning of progressive linkage setups and ratios until it was right. Believe it or not, we were able to get (freeway) 18.1mpg out of my friends 331 stroker Cobra and the motor was right at 430hp running the dual 450s. Another friend setup dual 600s on his Cobra with a 410merc FE. It rips, amazingly well. In each of these scenarios what struck me the most is it took a few times to get it right but once it was spot on, it was really fun to drive in every situation except the 390 dual 450 setup which we never got it dialed in. If I had to do it over again, I'd see a really strong carb specialist before running duals again, it could have saved us some time; I think. Trial and error I guess.
Duane
  #36 (permalink)
Old 10-11-2008, 02:48 PM
I would be interested as well.
Let us know.
Silver.
