Old 07-31-2008, 12:48 PM
TButtrick's Avatar
Default Spinners
Moved the last part of this conversation from the KMP forum.
Originally Posted by A-Snake View Post
Ok, let's start with your comment "I have a loop in the safety wire that I monitor before each drive." I took that to mean you had a loop in the wire around midway and if the loop straightened out the knock-off had moved. The wire in the picture is shown more or less straight showing the knock-off has rotated counter-clockwise which would be "loosen" on right hand threads. What am I missing?
Now that I look at your safety wire a few more questions come to mind. The wire looks rusted. Are you not using stainless steel wire? How is the wire wrapped around the segment of the wheel? Did you drill a hole in the wheel as I don't see the wire going around a segment of the wheel.
http://www.whizwheels.com/Tips/safetywiring.html
Maybe its the perspective. Here's what it should look like (with stainless wire). Yes I drilled the wheel and wrapped it around the webbing. The loop is still there in my second pic. You're just looking at it from the side.
Old 07-31-2008, 12:54 PM
TButtrick's Avatar
Originally Posted by cdnus View Post
Looking at your photos one can see clearly there is at least a portion of unthreaded area of the hub inside the spinner. On mine that is quite wide ( I will have to go out to the shop & measure to be exact ) if yours is the same you do not have enough thread holding the spinner on.
Craig
Went out & measured---3/4" protruding out of spinner.
1/2" unthreaded starter nipple--approx 2 threds=1/4" Total--3/4"
So if yours are manufactured the same, you do not have proper thread engagememt
Craig
The first thread from the outside of my hub is 1/4" in from the end. The outer most thread on the spinner is recessed about 3/8ths so trust me, they are fully engaged and the wheels are sitting flat against the hubs. The spinners from Vintage Wheels are deeper than most with more threads and yes, there was a change in the hub dimensions at Vintage Wheels.
Old 07-31-2008, 12:58 PM
BDHE's Avatar
Cobra Make, Engine: Superformance, PE 514
Wow!
I NEVER heard of anyone drilling their wheel before. I always loop thre safety wire (stainless) around a "spoke" in the wheel an appropriate distance from where the hole in my spinner is.
Old 07-31-2008, 01:02 PM
A-Snake's Avatar
Original Shelby Owner
Cobra Make, Engine: CSX2321
Was it after you drilled the wheel, or just now, that you realized there isn’t a need to do that?
There will also be a challenge in the future to get that ear of the knockoff in a ‘near’ position to use the same hole in the wheel?
Old 07-31-2008, 01:14 PM
Banned
Originally Posted by BDHE View Post
Wow! I NEVER heard of anyone drilling their wheel before.
My car came the same way, and each spoke on the spinner has a corresponding hole. So alignment is never a problem with the one tiny hole that is in the wheel. No stress cracks and the safety wire doesn't mar more of the paint around the wheel spoke (only a small side of it).
It works for me quite well.
-Dean
Old 07-31-2008, 01:37 PM
TButtrick's Avatar
Just personal preference and a cleaner look than wrapping the entire spoke IMHO. I indexed the wheel to a pin drive with a mark on each so it goes on the same way every time.
Old 07-31-2008, 01:48 PM
Rick Parker's Avatar
There was a post & picture some time ago that had the stainless wire running through a piece of very small rubber hose, such as wiper hose that was then wrapped around the spoke in an effort to prevent chaffing.
Old 07-31-2008, 02:32 PM
A-Snake's Avatar
I agree, much cleaner looking than this wheel.
Old 07-31-2008, 02:39 PM
Snakebit's Avatar
eYou can order small shrink tubing in different colors or nylon tubing from McMaster Carr to run the safety wire through and wrap around the wheel spoke to prevent chafing.
Snakebit
Old 07-31-2008, 03:11 PM
TButtrick's Avatar
I feel MUCH better now that I see an original with drilled wheels...PHEW
Old 07-31-2008, 03:50 PM
A-Snake's Avatar
I don't believe the wheels are drilled. Hard to tell in photo that the safety wire is wrapped around that segment of the wheel. The knockoff has a hole of course.
Old 07-31-2008, 04:04 PM
TButtrick's Avatar
Really? SH!T.. and I thought I'd get a good night sleep tonight.
Old 07-31-2008, 04:45 PM
ZOERA-SC7XX's Avatar
I don't think drilling a small hole in the wheel will hurt it, but having an interruption (bubble) in the 'twist' of the safety wire is not wise. The 'twist' strengthens the wire more than twofold, and movement back and forth of the spinner can flex and ultimately break the wire in the weakened area.
I also think generous use of the lead hammer will keep the knock-off from loosening.
Old 07-31-2008, 05:11 PM
Silverback51's Avatar
I take a short piece of wire and remove the copper strands from it and then thread the stainless wire through it. That way the wire does not wear on the paint of the wheel and it adds a little detailing touch to it, at least in my opinion.
I you look in my gallery, you will see a picture of how I did it.
Old 07-31-2008, 05:25 PM
wtm442's Avatar
Beam Me Up Scottie
Originally Posted by Silverback51 View Post
... that way the wire does not wear on the paint of the wheel and it adds a little detailing touch to it, at least in my opinion.
A short piece of vacuum hose or shrink tubing on the SS wire (over the painted portion of the wheel spoke) works too.
Ooopps - just noticed that this had already been mentioned. Never mind.
Warren
Old 07-31-2008, 06:52 PM
David Kirkham's Avatar
At the request of Jamo, I am posting this from the thread on the KM site.
Gents,
I do not mean to rain on anyone's parade or seem brash or abrupt when I say the following as I mean no offense to anyone. No one knows everything and we all learn together (at least I hope so). Hopefully I can shed some light on the subject.
I have seen more tequila on this thread than I have in many a thread combined. If any more appears, some politician will figure out how to put a vice tax on it.
When Jamo commented on "centrifugal force" wanting to unscrew the knock offs I decided he must have had an EMPTY bottle of tequila beside him before posting.
In reality, the direction of the threads is absolutely inconsequential as to whether or not your nuts nut come off!.
It makes NO difference which direction the threads run--right or left on EITHER side of the car.
Wing nuts come off for one reason and one reason only...they are not installed with enough clamping load on the wheel. Now, that said the level of "tightness or clamping load" required certainly varies with myriad reasons that would take me 20 pages to explain. Suffice it to say, an incredible amount of torque is required to develop the proper clamping load if you have sloppy holes in your wheels, your drive pins are under-sized or loose, or the taper on your wing nut-to-wheel interface is wrong as the point contact between the wheel and the nut will yield and then your nuts will be loose. (This is NOT an exhaustive list of all the innumerable things that can go wrong, by the way). On the other hand, NO torque (or clamp) is needed to keep a wing nut on if the wing nut is welded to the hub because it galled (a sad situation I have seen more than once--usually with stainless knock offs--but thankfully not one I have seen for years.)
To some of you, this may seem shocking. "WHAT, the direction of the threads doesn't matter!?", you say! "You must have an entire CASE of empty tequila beside you--along with some "happy weed" to boot to post such a thing! EVERYONE knows I have right hand and left hand nuts for a reason! There MUST be a reason--or, why would they DO it?"
Before you bust out the pitch forks (or more tequila), let me explain. The wheel is not held on by the DIRECTION of the threads per se--but by the clamping load applied BY the threads. The direction the threads run is completely immaterial to the clamping load the threads apply. (Just ask any poor soul who has had some unmentionable body part in a thumb screw if he (or she) asked the senor inquisitioner dude which way the devise was threaded before he "converted" to Christianity.) I am sure you would all agree with me on that. In fact, if you were to press a sleeve onto the hub with NO threads, it would do an equally satisfactory job of retaining the wheel (with the proper clamping press fit, of course). We only use threads for the convenience of being able to take the wheels on and off--hopefully only when we want to--or, for "convincing" people they really should convert.
To give you an idea of how much clamping force threads can (and do) generate, I post the following picture. Notice those huge I beams are BENT
As you can see, we are pressing on the threads (in an attempt to elastically fail the threads in a destructive test) with around 22 tons. Our press ran out of press before our nuts ran out of clamp. The threads were fine after our test as 22 tons was sufficient to convince me of such. Who needs brass nuts when aluminum ones do just fine.
I post the following link so you can see how much standard threads clamp. The diameter of a Cobra hub is about 2.3 inch by the way.
http://www.coxhardware.com/usefulinf.../7_btorque.htm
Now, if you don't believe me (and you shouldn't without going through a careful thought experiment of your own) then think of a harmonic balancer. The harmonic balance is held on with NO threads! It is only held on with the clamping load of the harmonic balancer bolt.
As for the knock off and the wheel rotating at different speeds...I think more tequila has been involved (and quite possibly an enormous amount of happy weed--legal California medical variety only, of course). If the nut is properly tightened, then it is absolutely IMPOSSIBLE for the wheel and the nut to move at different angular velocities. If you think about it, the furthest out atom on the aluminum of the the rim is moving at a higher circumferential velocity to the very next atom closer to the center of the rim--but there is NO relative movement between them as their ANGULAR VELOCITIES are identical. There couldn't be a difference in "w" (w=omega=angular velocity) as the rim is not tightening or loosening itself together or apart. If the nut is loose, then of course, all bets are off. The wheel can be moving at 2000 rpms and the nut at 0--where in you will very soon be in for a change of underwear.
Another thing to remember is you can brake approximately as fast as you can accelerate in a Cobra (even though we would all like to think otherwise). So, wouldn't braking have just the same detrimental effect on the tightening or loosening of the wing nut as accelerating according to the above "tequila arguments?" So, do we make the threads "self tightening" for braking or for accelerating; or, do we just never use the brakes... (The choice of some of the guys I have been on the track with ). Remember, an F1 car can decelerate at some 4 g's and they certainly can't accelerate at 4 g's so for the Jamo empty bottle argument F1 should make make the threads REVERSE of what they are on our cars... Alas, they don't. Some of the sharp guys on this thread may now say, "HEY! don't F1 guys use right and left hand threads!!!! HA!!!! You are BUSTED!!!"
Yes, they do...but why? Well, I have had LONG conversations with Metalore (the maker of almost all F1 and Indy car wheel nuts and hubs) and with the late Carroll Smith...
You know why they do it???
We all finally decided (in my deepest bass voice with a violin under my chin)...
"TRADITION, TRADITION!"
Yes, tradition. You see, that is the way they have always done it; so, that is the way they keep doing it. You see, pit crews don't change regularly and the guy on the right side of the car is trained to put on left-hand threaded nuts and the guy on the left side likes to use his right hand on his nuts. There never was a time for the team to change them--or a reason as right-hand-threads are the same weight as left-hand-threads.
Now, before this post gets too long and some of you run out of tequila, I should mention that temperature and many, many other things contribute to your nuts loosening up. I imagine the above guy has a sloppy wheel on his drive pins--something I have seen WAY too often. If there becomes relative movement because of a LACK of clamp, then who knows what can happen. Bottom line, make sure your nuts are tight! And if you are a Kirkham owner with the push button hubs, drill your hubs and SAFETY WIRE YOUR KNOCK OFFS UNTIL WE CAN FIGURE OUT WHAT IS GOING ON! Remember, if you don't tighten your nuts properly, you just might loose more nuts than you intend to!
Besides, safety wire looks cool.
As Issac Newton said, "The ONLY reason I see further is because we stand on the shoulders of giants."
Old 07-31-2008, 06:54 PM
This is what happens when the harmonic balancer bolt is not tight. Notice the key is NOT in one of the 3 notches of the timing chain. This is an expensive lesson in right-hand vs. left-hand threads and why you should tighten ALL your threads so your nuts don't fall off.
Old 07-31-2008, 06:55 PM
Another view of the sad day.
Old 07-31-2008, 06:57 PM
And yet another view of why we tighten our nuts and bolts. I guess I should add here a harmonic balancer takes TREMENDOUS abuse...that is why it is there. The explosions of the pistons are constantly vibrating and torquing the balancer trying to shake it literally off the crank...yet, you don't see any threads here. CLAMP is why it is held in place--or NOT held in place in this case.
Old 07-31-2008, 06:59 PM
Here you can see the key sheared from the beating (extreme far left side of the key way). Then the valves bent and the driver was left wondering why he had no more power on turn 4 a Miller Motorsports...
