10-31-2008, 08:37 AM
VA
How do you make an 815 CI engine ?
With all the gear heads here pushing the "limits" in so many posts, why has no one here done this??
http://www.youtube.com/watch?v=htTogHf153E
________
________
10-31-2008, 10:18 AM
wa
If I remember right, the Mountain Motors that the IHRA Pro Stock boys run are all at 800 Cubic Inches.
10-31-2008, 11:35 AM
VA
I guess what i don't get is that we have a huge argument about if you can build a 582 from an FE or not:
http://clubcobra.com/forums/showthre...threadid=91730
And then you see an 815 CI engine. What do they use a Mack Truck block ???
Obviously not, but then what ????????????????
________
________
10-31-2008, 01:07 PM
GA
Cobra Make, Engine: Yard Dog FFR 521, 572 Fire Ant Mongrel Cobra 393, 566, Boss 600 hemi , RCR40 #13 348
They are custom aluminum blocks with wider bore spacing and higher deck. With hemi heads, the 815 is 36" wide and much taller than a 460.
10-31-2008, 01:52 PM
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
Hi Ed, If I am not mistaken, The max you can safely go with an aftermarket 427 block (Pond, Genesis, Shelby) is 542. The max on a factory FE is 482 & it has to be a true 428 stamped service block. Not just a service block with the extra webbing but a stamped 428 service block with the thicker cylinder walls. The max on a Ford 385 series block is 815 & they are run by the Top competitors in NHRA & IHRA producing about 9000 hp.
Come to think of it, I wonder how they Dyno them??
Just my 2 cents.
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
10-31-2008, 03:37 PM
Beam Me Up Scottie
MA
9000 HP ??????????????????
Try about 1800 to 2000 HP in a Top Sportsman car.
What class in NHRA allows an 815 cu in motor?
Warren
10-31-2008, 03:56 PM
MO
Cobra Make, Engine: SPO 2715
Top Fuel, and on a good day Top Alcohol get up to 8,000 hp @ 456ci?
456ci is tops right?
E
10-31-2008, 04:49 PM
Here's a bit of info about top fuel from Kenny Bernstein's web site:
Engine
Supercharged 500 cubic inch TFX aluminum hemi V-8 block
Bore & Stroke
4.19 x 4.50 inches
Horsepower
7,000 to 8,000
Acceleration
Zero to 100 miles per hour in .8 seconds
Zero to 275 miles per hour in 3 seconds
Zero to 330 miles per hour in 4.5 seconds
I understand they can go 0-60 in one car length...
Here's the pro stock mountain motor info from Jon Kaase's site:
815 Cubic Inch Pro Stock Ford HEMI Engine
1700+ horsepower
Since the deck height is much greater than the production block based engines, you could probably fit one of these in a Cobra if you moved the hood upward by about a foot...
10-31-2008, 05:08 PM
E
Hi E, Yes, Top Fuel. Tony Schumacher runs 500 cubes. I'll try posting a link to a good read. I don't know if it will be a hot link or if you have to copy & paste into your search engine.
http://www.edmunds.com/insideline/do...ticleId=120159
Also, I think the Pro Stock & Pro Mod classes run 815 cubes. Anyway, The Top Fuel & Pro-Stock/Mod engines are incredible & huge dollars. Just to stand next to one when it's launching is an experience all by itself.
Mick
10-31-2008, 05:42 PM
wa
All Pro classes in the NHRA are limited to 500 CI engines.
10-31-2008, 06:14 PM
Correct!
Sorry to confuse by not being more specific: IHRA allows "mountain motors", currently topping out around 815 cubic inches
10-31-2008, 06:18 PM
Cobra Make, Engine: Sage Brush Roadsters body, Custom Chassis, SRT-4 Engine
From the 2008 NHRA Rule Book...
Pro Modified:
No supercharger: 820
Supercharged: 527
Top Alcohol Dragster:
No supercharger (uses nitromethane instead of methanol): 456
Roots supercharger (methanol): 528
Screw-type supercharger (methanol): 466
Top Alcholol Funny Car:
Roots supercharger: 565
Screw-type supercharger: 528
Pro-Stock: 500
Top Fuel Funny Car: 500 (also has a minimum of 490)
Top Fuel Dragster: 500 (w/ 490 minimum)
10-31-2008, 06:34 PM
Thanks for posting the rules. I didn't realize there was a minimum in the 2 top fuel classes. That's interesting.
Mick
10-31-2008, 07:04 PM
wa
Pro Modified:
Supercharged: 527
Pro-Stock: 500
I forgot about the Pro-Mod class. Thanks for correcting me.
10-31-2008, 08:44 PM
If you think this will fit in a Cobra ..Think Again. This is 698" Kaase from a couple of years ago:
[IMG]  [/IMG]
10-31-2008, 09:07 PM
No problem.  I wasn't trying to "correct" anyone though, just had the book here at my desk so I looked it up and posted what I found.
I didn't realize how "limited" the Top Fuel class really is. Basically it looks like everyone is running the same car, it's just a matter of how good your tuner and driver are.
I also didn't realize that you could run a Naturally Aspirated dragster on Nitro in Top Alchohol either. I wonder if anyone actually does that?
10-31-2008, 09:16 PM
Beam Me Up Scottie
MA
Quite a few run that way, and a couple are always in the running to win any race.
Warren
10-31-2008, 09:37 PM
The nitro cars that run in TAD generally get beat by the tuning as they are much more difficult to get right. They often put out a cylinder during the run.
11-01-2008, 06:35 AM
wa
That's the problem.
If they run good, they have a real good chance of winning. They just need to keep all eight cylinders lit.
