Like Tree1Likes
Old 11-14-2008, 04:23 PM
marcalan's Avatar
Cobra Make, Engine: era 289 FIA #2112
I had to have Doug at ERA send me a pedal stop to for the clutch to limit the travel.
m-a
live for the moment or it may pass you by
Old 11-14-2008, 04:40 PM
Dangerous Doug's Avatar
marcalan: Really? It looked like I was going to have to do the same, but Doug told me that I can take the lower lever off the clutch and rotate it to get the position I want. Sure enough, I was able to rotate it and get the recommended ~1" throw at the master cylinder. The lock pin is hard to see, as it is on top of the lower lever.
Right now I have the master cylinder rod on the upper hole on the lower lever. If I switched to the lower hole that would get me to about 1-1/2" travel.
Seems to work. I'll find out tomorrow.
Doug "Got-the-Bug": Give me a call so I can crate "The Guardian" (a.k.a. Donner, my German Shepherd, also known as "The DogFather")
Dangerous Doug
"You're kidding, right?"
Old 11-14-2008, 05:05 PM
marcalan's Avatar
Doug, Yes, I too had to take off the the lower lever and rotate it on the splined shaft. I had to do this to move the lever towards the seat. I ended up moving the brake pedal as far forward as possible as well. The accelerator was adjusted to be parallel to the other pedals.
I had to do this (5' 2") in order to reach the pedal. They really set the car up for much taller folks.
Old 11-14-2008, 05:09 PM
Roscoe's Avatar
I'm using the Tilton floor mounted pedal set. It has a built in stop adjustment.
Roscoe
Roscoe
Old 11-15-2008, 09:31 AM
Snakebit's Avatar
Doug, I did the same. 5'6" with a 29" inseam the steering wheel was almost hitting my chest. Rotated the clutch pedal on the splined shaft and put extensions on the brake pedal shafts. At least I did not have to use a booster seat to see over the steering wheel!
Snakebit
