11-20-2008, 06:11 PM
Anyone using the C.W.I Jag rear inboard brake setup
I am looking at the CWI Jag rear brake setup that takes the inboard brakes and mounts them on the rear facing side of the differential instead of forward facing. They include Wilwood calipers, Wilwood parking brake calipers, etc. What do you actual users think of the setup? Do you know the part numbers for the calipers and the parking brake calipers? I would like to do some research on what they are using. Also, does it use the stock rotors? Any and all details on the kit, how it works, the pluses and minuses, the parts used etc.... would be greatly appreciated. Thanks.
11-20-2008, 06:26 PM
Doug
Why not just convert to the George Petrus outboard design?
11-20-2008, 06:39 PM
The CWI setup is only $695, I can't imagine what George gets, his stuff is VERY pricey! How are you, Jeff?
11-20-2008, 06:47 PM
Great
Installing dual batts behind passenger seat, they look great!
11-20-2008, 08:25 PM
Hey Doug, do you need me to make some of these adapters?
http://www.xks.com/shop/jaguar/ACCDe...spx?catID=5136
Bugger it lets make outboards!
11-20-2008, 08:34 PM
Why bother?? How often do you think that you will have to change rear pads? Anyway I have the stock jag setup and it takes 5 minutes to change the pads. Why spend the extra money and time????
11-20-2008, 09:00 PM
Originally Posted by mickmate
Nick,
You have a Private Message!
11-20-2008, 09:03 PM
John,
I suspect our car bodies are different. On the Contemporary that I own, the calipers are pretty tight against the body, and the pads are tough to get to without dropping the rear suspension. Jag actually had a trap door arrangement on the E type that these came from, I'm told, in the car to allow access through the floor.
11-20-2008, 09:42 PM
John you've got to understand this is coming from a guy who pulls a nice car apart to make it better. We don't understand him either but we humor him
11-20-2008, 10:55 PM
Regularly Offensive
Cobra Make, Engine: spf
I have a Jaguar with the inboard brakes. You are going to hate them. I know you don't plan on working on the brakes very often but when you do it is more than an all day job. Everything back there has to be removed to change the rotors. By the boook it is a 10.5 hour job.
My 2 cents
Ed
Ed
Too close for missles, switching to guns.........
11-21-2008, 06:00 AM
I don't have a Contemporary, but working on this rear axle and the brakes is a BIG nightmare. ANYTHING you can do to make the job easier, do it.
I just got done cutting a 'trap door" in my car.
11-21-2008, 06:09 AM
I have the CWI vented rotors and widened Jag calipers in an E-M. They work great, both road and track, and the pads take less than 1/2 hour to change with the car on a lift. The rotors are another story....
Tom
11-21-2008, 03:15 PM
Because outboard brakes on our cars tend to separate the wheat from the chaff.  *
* On a fully-independent, limited slip, pin-drive set-up of course.
Reason: Added the after thought to avoid snide remarks....
11-21-2008, 05:36 PM
UK
Originally Posted by 1985 CCX
Great
Pictures?
11-21-2008, 06:14 PM
Paul,
I will try to send some this weekend. Still do not have the cables installed. BTW: I used your Rebat label Thanks!
11-21-2008, 08:01 PM
My rear end is Jag with inboard discs and limited slip (2.88) and....and.....and.............
11-21-2008, 08:25 PM
...and chaffy?
11-22-2008, 07:10 AM
WI
Yes, and so do single rollbar hoops!
Tropical Buzz
11-22-2008, 07:11 AM
But you can't use roll bars for fodder.
11-22-2008, 07:41 AM
Tom Well
I can change out my pads in 30 minutes as well even with inboard brakes on my CCX. Seems like the XJS might be a nightmare since it is so packed in?
