Like Tree1Likes
  • 1 Post By 1bad66
Old 12-08-2008, 03:35 PM
Question Spring for rear
We are building a 1992 CMC kit. The rear springs have been in the chassis since 1992 and although they look brand new the rear end squats way too much under hard acceleration.
both springs are marked with "350" I don't know if that is a part number or has something to do with the spring rate.
Coil Spring specialties will build any size and rate we want, the question is
What rate?
Old 12-08-2008, 03:37 PM
1bad66's Avatar
Cobra Make, Engine: Streetbeast, 351W
are they for a stock mustang rear end? If so, I have a set of stiffer spings I might let go.
CHANMADD likes this.
Old 12-08-2008, 03:47 PM
Default That's the spring rate per inch
727pilot That is the spring rate per inch of travel. 350 pound load to compress the spring 1". You want the car to squat to put added load on the rear tires for traction. If the rear is squatting too much adjust the dampeners on the rear shocks. 350 is a good place to start for a street car. The only thing you didn't say was what is the angle of the shock in the car from mount to mount. The more angle on the shock and spring, the more dampening you need. Video the car squatting, the rearend should drop about 1-1.5" total. Thats a good start. Are the tires rubbing the inner fender wells? Have you had the car weighted at all 4 corners? Wheel alignment? Find a dirttrack guy with scales and get the car balanced with your weight in the drivers seat. Next get the car aligned with a thrust angle of 0 degrees. After this is done see what you have. Does your car have 2 or 4 shocks in the rearend? Answer these questions and we will give you the best direction to go. You have to remember that a street setup is alot softer than a race track setup. about a 35-40% increase in spring rate alone. This will also make the car ride like a truck on the street. Fill in the questions. Angle on the shocks is IMPORTANT also Rick Lake
Old 12-31-2013, 05:13 AM
Cobra Make, Engine: StreetBeasts, 331 Stroker
I have a Streetbeast and am trying to avoid a bit of rubbing on the rear, currently at 375# springs, thinking of moving to 450s to avoid this problem but not sure if that's the right move, please advise.
Old 01-21-2014, 02:31 PM
Beastly's Avatar
Cobra Make, Engine: Fiberfab international classic cobra
Redeye check out the discussion we have going on the streetbeast social group. We may have an answer for your rubbing under load. -Beastly
