Old 01-04-2009, 10:37 AM
Double Venom's Avatar
Default "The Spinning Cobra Air CleANER" No more!
For years I like most builders have put up with the oblong Cobra Air Cleaner turning/twisting under load, chipping the hood paint, and haveing to straighten up everytime I lift the hood, well not any more!
A "cheap" and inexspensive absolute fix that works and if seen at all looks good. How many custom changes can a builder brag about both those claims?
This is a link to the post of "cpteddies and DV's build." I hope it goes directly to the page but if not it's on page 13/14 (?) of all the posts.
That other guy named Ed and DVs CRII build
Hope this helps others with the same problem!
DV
Old 02-06-2009, 01:04 PM
Tom Wells's Avatar
Hey Ed,
Hope you're not still freezing your spheroids off
Here's the fix that I put in to stop the spinning:
http://www.firstcoastcobraclub.com/v....php?f=8&t=371
Note that nothing can fall into the engine if the roll pins fit the carb tightly.
It has worked for 20K miles plus!
Just another two cents,
Tom
Old 02-06-2009, 01:13 PM
Tom,
First day above freezing since first week of January!
Nice... ! Did you see where I went back to cpteddies and changed the flange nuts to regulat nuts and wired them in like the spinners?
DV
Old 02-06-2009, 01:28 PM
Banned
DV
For those that want to solve this problem AND add additional hood clearance, you may want to go this route.
-Dean
Old 02-06-2009, 01:34 PM
TButtrick's Avatar
I took a length of rubber vacuum line and slit it lengthwise then used rubber cement to attach it to the air cleaner base circular edge where it meets the carb. Works great.
Old 02-06-2009, 03:07 PM
undy's Avatar
I find this method keeps the air cleaner from twisting too...
Too many toys?? never!
Old 02-06-2009, 04:38 PM
Tom Wells's Avatar
DV,
I hope some of your solid water goes away with that huge temp rise
We even had some freezing here, but it seems to have gone away now - I'll be driving the Cobra tomorrow to a show.
Undy,
I do like your method!
Tom
Old 02-06-2009, 08:34 PM
Red
Where do you get one of those dropped bases?
Old 02-06-2009, 08:57 PM
MEATMASTER's Avatar
Cobra Make, Engine: Johnsonville, 8-pack $4.27
Default They're not supposed to spin, huh.
Gee, here I thought they were supposed to spin. I guess I better stop lubricating mine with WD-40.
MEATMASTER "... don't know much about cars, but sure do when grillin..."
Smoke the meat, only the meat and nothing but the meat... so help me Weber
