Like Tree2Likes
Old 01-05-2009, 08:31 AM
priobe's Avatar
Default Thinking of heat shield for Sidepipes
Hello All,
I am thinking of purchasing the heat shield for the sidepipes.
My question is do they really work to prevent burns ?????
Old 01-05-2009, 09:41 AM
mln385's Avatar
Cobra Make, Engine: BDR
Yes the do help but I hated the looks of them so took them off.
1 suggestion if you buy them, under the pipe clamps that secure them put some fiberglass matting to prevent scuffing.
Marc
Old 01-05-2009, 10:07 AM
Bill Bess's Avatar
I agree, I hate the looks of them, so here is what I did.
Purchased two small welding blankets (approx. 15''x15") , attached a small strap to each blanket and then attached the strap (with a snap buttom) on the inside of the car near the door thresholds. The blanket is rolled up and tucked between the seat and the door opening when not being used.
If a person that wants protection from the heat of the pipe while entering or exiting, they simply unroll the blanket over the hot exhaust pipe.
It works perfectly and costs only about $15.00 for the entire set-up. The blankets can be purchased at any welding supply company.
Bill
raybones likes this.
Old 01-05-2009, 10:19 AM
Originally Posted by Bill Bess View Post
Purchased two small welding blankets (approx. 15''x15")...
I do the same thing, but just flip them out. I went through a stage this last year where I burned my leg every other time I drove the car with shorts on. For some reason I just couldn't remember to stick my leg out a little farther when exiting. Here's a thread I posted on the subject that includes pics of the welding blanket: Rick Lake - Thanks for this Tip!
MLI likes this.
Old 01-05-2009, 11:26 AM
scootter's Avatar
They help, but don't prevent burns. My daughter still burned her leg. Probably not as bad with out them. The problem with my shields, the clamp towards the rear is right where you step out of the car. It transfers all the heat right to the shield.
I bought my car with them on. I had one break and was going to leave them off, but the coating is all messed up under the clamps.
The best thing is to stand up and step out when getting out, and put both feet in the car and slide down into the seat when getting in.
Scott
Old 01-05-2009, 11:37 AM
Although my only "real world" experiance was the side pipes on my Vette.
I noticed that getting in and out of the Cobra my calf would get fried so I will run heat shields. It's real awkward trying to keep your leg out that far and I don't bend as well as I used to...
I've lost some skin on the darn jack hooks a couple times now too, so I'm putting over-riders on instead.
Old 01-05-2009, 04:59 PM
ZOERA-SC7XX's Avatar
I made a set and they don't look bad. They are flat black like the sidepipes and I've had no burns to date, same for my passengers. Check my gallery.
Old 01-05-2009, 06:28 PM
Gatorac's Avatar
Cobra Make, Engine: BDR 930, 427 Windsor T56
Learn to enter and exit the car like Scooter says and you won't get burned anymore.
Step into car with both feet standing up. Sit down into seat. Getting out is the reverse. Your legs don'e get close to the pipes anymore. With a top on it's a little more difficult. Crawl into car head first putting your knees on the seat. Rotate to a sitting position.
Always instruct first time passenger the proper methods as well.
Looking under the hood with shorts on will still get you. Heat shields won't help with that anyways.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
Old 01-05-2009, 06:36 PM
Too much trouble. It's easier to just use this:
Old 01-05-2009, 10:16 PM
car4jim's Avatar
Cobra Make, Engine: Kirkham, 427 side oiler
Isn't there some theory of evolution that would suggests you only get burned once....and that's it! Only with the charred flesh comes true enlightenment! I'm with patrickt!
Old 01-06-2009, 05:50 AM
Archrms's Avatar
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
Getting in and out of a Cobra as you would a regular car is a guaranteed burn. I've seen cars with the heat shields on, and they seem to still get hot enough to burn skin. Depending on what type of shields you get, you can get a nice "pattern" to your burn, like with the slotted type
Peace through superior firepower...or is it horsepower? Either way, more is always better!
Old 01-06-2009, 06:42 AM
Darwin never drove a Cobra... and the back of my left ankle looks like I have been standing in front of the business end of a flame thrower. Honestly, I don't really care about me (and I found that 409 removes burned flesh stains from ceramic coating) -- I got the welding blankets for my kids, passengers, and morons at car shows that come up to the pipes when they're still hot.
EDIT -- Seriously though, Silver Sulfadiazine is great stuff for the burned ankle -- maybe ENTDOC will write you a standing prescription....
Last edited by patrickt; 01-06-2009 at 06:47 AM.. Reason: Added the serious note on Silver Sulfadiazine
Old 01-06-2009, 06:56 AM
Terry Brown's Avatar
Cobra Make, Engine: Superformance, #930, 351W/427CID 419 RWHP (before the Webers!)
These heat shields were made by Stainless Steel Specialties. They have saved many a leg and look as good, or better, than the pipe/muffler alone (IMO).
They will make them any length you want. These are longer than than standard ones. I wanted them to extend past the door almost to the pipe ends.
Terry Brown SPF #930 427W 419 RWHP 48 IDA Webers
"Remember, your car will not be more valuable after Track Day than it is the day before the event" - Eric W. instructional presentation on Track Day safety, 05/15/2008 WSCB
Old 01-06-2009, 07:07 AM
Cobra Make, Engine: CMC 427 S/C - 351w
I am used to getting in and out of mine without getting burned - but - the hot side pipe is a great excuse to help or even pick up and place a lady in the passenger seat.
Old 01-06-2009, 07:32 AM
CobraDan's Avatar
Backdrafts
http://www.backdraftparts.com/shopexd.asp?id=68
Dan Wulff
Old 01-06-2009, 08:05 AM
Got the Bug's Avatar
Luckily, I've only been burned one time. I was opening the hood and my ankle touched the pipe. It's become pretty automatic to plant my feet and step over the pipes. I ususally just tell passengers to stay put until I can come over and help them out.
The heat shields are fine if you already have them, but like Scott said, you can still get burned.
Doug
Old 01-06-2009, 09:51 AM
RodKnock's Avatar
The Hushpower sidepipe muffler, which is a subsidiary of Flowmaster, is a slightly quieter muffler and, according to their technology section of their website, their exterior muffler surface temperatures are reduced.
I have "tested" mine out yet by touching them, but it was a major reason for my choice.
Old 01-07-2009, 05:50 AM
Archrms's Avatar
Terry,
Not to side track this thread, but what make and model of lift is that in your garage? How do you like it, and what price range is it in?
Old 01-07-2009, 07:08 AM
CBattaglia's Avatar
Cobra Make, Engine: Gary Edwards Racing 460
Ive been told my many that the heat shields dont prevent burns they just make a prettier burn pattern! I always remind my passengers so none have been burned yet. Me, I get zapped every so often.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
Old 01-07-2009, 07:15 AM
paulbarrick's Avatar
Cobra Make, Engine: Backdraft,427R
I have the Backdraft shields with all the holes in them, look OK, let the heat out and they don't seem to get very hot...best idea is to learn to stand up when getting out, people around will stare at your athletic ability....my wife hasn't learned yet, so I go around and open her door, just like when we were dating...makes her smile
