January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 01-16-2009, 09:43 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Default Cobra cutting out
The other day I took my son out for a 1/2 hour drive. Everything was fine. On the home stretch I decided to piss off some golfers so I gunned it pretty hard. The engine cut out 3 times. Not your typical hesitation, but on-off-on-off-on-off. Absolute silence between these split second 'offs'. Then it was fine, golfers pissed, mission accomplished.
Then yesterday I warm her up for 5 minutes, drive up to a stop light, press the clutch and the car dies. Crank it and nothing. Switched on and off the fuel pump switch a couple times like some WWII Ace about to crash land. I limp to the side of the road. Won't start. Engine looks good, still cold. I crank it again and viola! No problem for the 60 mile round trip.
My confidence is waning. I have a 5 year old Roush 402R/SPF. The installer took out the mechanical fuel pump and I can't find the electrical one. I presume it's by the tank. All I see is a braided line going from the carb and down through the tunnel.
My neighbor thinks it's the ignition, MSD/Fireball. Pump makes quite a loud noise when ignition is on. When I start, I usually turn the key on, let the pump work for a few secs, pump the gas and start. The installer also took off the choke for what that's worth.
Any ideas? Could fuel boil while engine is cold? Loose ground? How many ground connections are there?
Old 01-16-2009, 10:01 PM
xlr8or's Avatar
I would look for a bad ground or loose connection. Check the MSD wiring on the ignition box. Also check the fuel level in the bowls it might be a sticky float or needle/seat is dirty.
Old 01-17-2009, 06:10 AM
Definitely electrical. A fuel problem wouldn't have your on/off symptom.
It could be in so many places in the ignition circuit, from the ignition switch to a bad distributor, and everything in between.
Old 01-17-2009, 08:09 AM
Blittleton's Avatar
CC Member / Sponsor
I would agree with the ignition module in the distributer. I have seen several fail with that same type of discription.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
Old 01-17-2009, 12:11 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
You said, "...Crank it and nothing..." Could you clarify that a little? Did it actually crank...or do nothing? If it didn't even turn over I would look at the battery ground first, then the ignition switch. If it turned over but did not fire, check the easy stuff first, power and ground on MSD box. The 2 wires on the coil, inside the distributor cap/center contact. Do this easy/cheap stuff first...then start spending $$$$..
SPFWiringDiagrams@Comcast.net
Old 01-17-2009, 12:45 PM
Fordzilla's Avatar
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
Sounds electrical. Hopefully you can find it relatively quickly as some times these things can drive you crazy!
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
Old 01-17-2009, 04:51 PM
Those golfer Gods can play dirty when pissed off!
Good luck.
Jim
Old 01-17-2009, 09:51 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Default drove it today
I should have clarified, it did crank. It was as if I had no gas. I spoke with a couple of local mechanic friends and they said loose ground or ignition. All connections looked good.
I showed off a bit for my friend, an old Corvette and Porsche guy. He loved it and we really hit the rev limiter a few times. No problems today.
Now that the warranty is long gone, how much higher could I adjust the limiter and be safe? 6500, 6800? The reason I ask is because the motor is hitting her stride at 6200 (current limit), she's seems to have alot left. Any of you guys mess with the rev limiter?
Back to the original problem, are the Fireball ignitions good? My friend said they didn't have a good reputation quite a few years ago. Any suggestions?
Thanks, I really appreciate thr brotherhood!
Old 01-17-2009, 09:55 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Default Golfer Gods
jhv48,
You're right about the golfer gods. I live in a golf course, and these wierd problems only happen around the perimeter of the course.
Next time I'm getting a dirty look at a guy about to tee off, I'll throw him a Cohiba
Old 01-17-2009, 09:58 PM
Fordzilla's Avatar
Unless you are racing it competitively, I can't see any reason to spin it more then you are. I'd play it safe & enjoy the motor for a long time. If money isn't an issue, then let her rip!
Mick
Old 01-17-2009, 10:12 PM
Blas's Avatar
Well, if you say the powers & grounds are good...both at battery and by starter....I'm thinking coil, MSD box or ignition switch.
Go to the MSD website and find the coil test information.
Simple test with a volt/Ohm meter....
You can also find the test procedure there for the MSD box, also quite easy to do. Get thru that testing first. Costs nothing but some time...Did you look at the rotor and center contact in the distributor?
Old 01-17-2009, 10:21 PM
Cobra Make, Engine: Unique 351w stroked 396
I had something happen to mine that sounds exactely what is happening to yours . I have an MSD Ign. in mine and the Rev limiter was bad .
I dont race mine so I just removed the limiter switch and no more problems .
Rick
Old 01-18-2009, 12:26 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
Default checked distributor
Blas,
I checked the ditributor tonight. There was a tiny bit of scoring? on the outer magnets but O don;t think that's it. I'm going to check the MSD site and get that test procedure.
traveler,
What do you mean 'removed the rev limiter'? You mean set the limit very high? Mine is in the finned Fireball box that looks like a car stereo amp. Doesn't that control the coil when to spark or is it only the limiter?
Old 01-18-2009, 12:48 PM
Originally Posted by rodneym View Post
What do you mean 'removed the rev limiter'? ... Doesn't that control the coil when to spark or is it only the limiter?
He means pull the chip out of the side of the MSD unit -- that chip is the "rev limiter" and interrupts the spark at a given RPM. And yes, the MSD unit controls when the coil's field collapses to cause the spark at the plug. FWIW, the way I tackle intermittent electrical problems (assuming that's what you've got) is to hook up different colored test lights to each part of the equation and have the lights literally right in front of me (taped to the dash, sticking out from the hood, it doesn't matter). When the problem occurs, look down and see what light(s) are not working and that will give you a clue. I just did that recently for a faulty ignition switch in my Cobra that was giving me intermittent no crank situations, and seconds later, cranked up perfectly. Before hooking up my test lights, I was sure it was the solenoid (wrong), battery (wrong), starter (wrong) ... and it proved to be the ignition switch. When the car wouldn't crank the light feeding the ignition switch was on and the light feeding the solenoid from the switch was off. Jiggling the switch just right could make the light blink on and off. By any chance do you have your coil mounted horizontally? If so it needs to be the "Hi-Vibration" Coil, otherwise you can get air pockets over a winding that can cause intermittent faults. Unless you know that little trick, it's a real pain to diagnose.
Old 01-18-2009, 02:34 PM
undy's Avatar
MSD ignition modules have a tendency to fail. 400 to 1300 ohms is what you should read through the pickup.
MSD has a relatively good diagnostics on their web site.
http://www.msdignition.com/page.aspx?id=3206
http://www.msdignition.com/instructi...terms=magnetic
Too many toys?? never!
Old 01-18-2009, 03:11 PM
They do have good diagnostics. But the problem is that an intermittent fault never occurs in the comfort of your garage. Rodney, here's a "down and dirty" plan that I've used before in similar circumstances -- put a can of starter fluid in your car and the next time it dies and won't start (but cranks) quickly open the hood and pull the #8 spark plug wire and hold the tip while you reach in and turn the key and crank it. If you get a shock, put it back on the plug and see if the car will start. If it won't start, quickly remove the air filter and shoot some fluid down the primaries and crank the engine. If the engine starts and dies, then it's a fuel problem. If you were able to hold the tip of the plug wire while reaching in and cranking the engine, then it's an electrical issue for sure. If you have a pacemaker in you, have a friend do the wire-holding....
Old 01-18-2009, 04:27 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Red face but wait!
Hey guys,
I really appreciate the help but a couple things:
1) The ignition module is the Crane Cams Fireball, The distribitor is MSD.
2) I can't crank without the clutch in!
Old 01-18-2009, 04:56 PM
And if you wake up on the garage floor and have pissed yourself, the ignition is fine.
Jim
Old 01-18-2009, 05:05 PM
Think of it as electroconvulsive therapy on the cheap. Frankly, I think a couple of the members around here could really benefit from it....
Old 01-18-2009, 06:33 PM
Cobra Make, Engine: EverettMorrison,408W,Jag rear, toploader
replace the module in your MSD distributor
