December 2025
Old 01-27-2009, 03:38 PM
coinop101's Avatar
Cobra Make, Engine: 1985 Cobra 427
Default 427 FE Ignition Setup
Ok
It's been a long time and a lot of advancements in ignition systems . My 427 FE has the old single point stock distributor and coil setup . I want to install a new MSD Ignition . I'm looking at a mechanical advance MSD distributor , but what about a Ignition control ? and HVC coil ?
What works best as a system and what does a ignition control do and do I need a high voltage coil ?
Thanks ,
Peter
Old 01-27-2009, 03:56 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
All you need with your distributor is a MSD Blaster coil and a 6al2 ignition box. Also, just call the guys at MSD. They're real helpful.
" It ain't no big deal"
Old 01-27-2009, 04:50 PM
Also get the optional MSD capacitor -- it helps guard against surges and will protect your box. Plus, if you're going to mount your coil horizontally make sure you get the "Hi-Vibration" model and not the oil-filled Blaster coil.
Old 01-27-2009, 07:13 PM
You should come down to classic concepts (Nic's) Edison ave off staight path in lindenherst , there are a few cars to check out , Also (Bill Andrews)@HRE Motorsports in freeport on Buffalo ave, on saterday mornings .
