December 2025
Old 02-27-2009, 03:46 PM
Cobra Make, Engine: Backdraft 427 Stroker, Sterling Gray/Silver
Default Holley Double Pumper casting failure !!!!!
I don't want to scare everyone out there running a Holley carb, but..............
A few weeks ago I had a steady drip of fuel leaking from one of the main fuel inlets on my Holley 750 DP. When I took the fuel fitting off and inspected the carb, I noticed that the main body of the float was literally breaking apart!!!!
The interior threads had what appeared to be bits of metal or silver sand.
I called Holley and they told me that a limited number of carbs (Unknown #) were sent out to a contract company for casting. In order to cut costs, the company used WAY too much lead in the casting.
As a result, the gasoline actually attacked the casting and began to break it down structurally. The car was built in 2006, but I'm not sure about the year of my carb production.
I sent my entire carb back and Holley confirmed it was one of the faulty castings. A brand new unit is on the way, but now I have to get it re-tuned.
If I did not notice the leak when I did, it would have been very likely to have caused a major engine fire.
I don't believe a recall or TSB was ever issued on this problem.
BEWARE!!!!
Old 02-27-2009, 04:00 PM
wtm442's Avatar
Beam Me Up Scottie
By any chance did you copy all the numbers off the air horn? The date code is part of the numbers. If not, how about a guess.
I also have a 750 CFM Holley. The car and engine was built in 2001, so I assume the carb was 2000 or 1999 manufacture.
Warren
Old 03-04-2009, 10:45 AM
Sorry Wtm,
I didn't copy down the build out number, but it appears it was a limited run in 2006. They didn't tell me how many carbs were produced.
You should easily be safe with your DP 750.
I received my all brand new DP 750 carb in a factory sealed box yesterday.
Old 03-04-2009, 11:50 AM
Cobra Make, Engine: spf 2112 *427 stroker windsor
get a DEMON.
Old 03-04-2009, 12:09 PM
Originally Posted by carmine View Post
get a DEMON.
Yeah, each Demon is shipped with ground-up Holley shavings in every unit
Jim
