Old 03-05-2009, 02:30 PM
redss454's Avatar
Cobra Make, Engine: streetbeast kit
Default Oil pan clarence
Any one know the distance from the ground to the bottom of their oil pan in inches? Jim
-Chris
Streetbeast Cobra Kit
71SS454 Chevelle with just a bit of work done to it
Old 03-05-2009, 03:26 PM
Cobra Make, Engine: B&B Mfg with '66 289ci
I had only 3" with my deep sump oil pan. Pulled it off last night and put a stock pan back on. This gained almost a full 2". Brian
Old 03-05-2009, 03:34 PM
427 S/O's Avatar
3" and see my gallery.
Perry
Old 03-05-2009, 04:02 PM
mickmate's Avatar
Originals had a little more than the frame clearance as they were just above the rails. Very dependant on the ride height.
mickmate
http://www.actoncustom.com/
Old 03-05-2009, 05:08 PM
jrjmac1's Avatar
I started out with 3". Then I put on coilovers, all four corners and replaced my stock pan with one 1" shorter. After ride height adjustment I picked up 3 additional inches. I can go over speed bumps now without fear!
"Live Life Abundantly"
Old 03-05-2009, 05:47 PM
Banned
I'm presently at 4.5", which is roughly the same clearance as the front oil cooler shroud and my cut-down McLeod safety bellhousing. Pic was taken from an angle so it looks a little less here.
-Dean
Old 03-05-2009, 08:05 PM
pgermond's Avatar
3"......... seems to work out okay
Phil
http://www.uniquecobra.com/
Old 03-06-2009, 07:13 AM
I changed my oil pan because of a PA inspection criteria called "scrub line". This is measured by taking string from the lowest point of the rim on one wheel and then extending to the opposite wheel where the tire touches the ground. Perform this for the opposite side as well. Where the lines intersect is the lowest point that PA states nothing shall lie below. This is in case you get a flat tire so you are not scraping the road. My oil pan fell below this, thus the reason to get a shorter one. Brian
Old 03-06-2009, 07:46 AM
redss454's Avatar
Thanks for all the information,Jim
-Chris
Old 03-06-2009, 08:34 AM
Cobra Make, Engine: Unique 427SC
Mine used to be 1 3/4". Then after I welded the oil pan from scraping holes in it it's now rides at 3".
Old 03-06-2009, 11:44 AM
Mine in 3 1/2 inches. The front crossmember is about 4". A little scary to think that the pan is lower than the frame. Hope I/we do not run over anything on the road.
Old 03-06-2009, 07:30 PM
mickmate's Avatar
Hot Rods/ Street Rods have the scrub line requirement in a lot of states. That is if you let all the air out of all the tires at once no part of the car will scrape the road (except the rims).
mickmate
Old 03-06-2009, 07:36 PM
bobcowan's Avatar
I wouldn't let it hang below the frame rails. That's just asking for trouble, IMO.
Old 03-07-2009, 07:48 AM
I agree, How much lower profile oil pan can I put in a 351W. Where can I order one?
Terry
Old 03-07-2009, 12:28 PM
bobcowan's Avatar
Measure the distance from the pan rail to the bottom of the frame rail. On my car, it's 7 3/4". I have a 7qt pan from Canton that's 7 1/2" deep.
http://www.breezeautomotive.com/deta...d=515&cat_id=8
Old 03-07-2009, 03:29 PM
I'll check it out.
Thanks, Terry
