Old 03-15-2009, 09:29 PM
CC Member / Sponsor
Neutral
Default Ethanol problems
We may need to set up our cars to run on a higher gas ethanol blend.
http://online.wsj.com/article/SB123716798764436701.html
Also an interesting case study for unintended consequences and of course tax dollars being wasted.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 03-16-2009, 05:42 AM
Cobra Make, Engine: FFR 5013 - Warmed up & enlarged 302, carb- Painted RED
I guess that the higher food prices that current ethanol production causes is of no concern to the "general"
It's not the size of the dog in the fight, it's the size of the fight in the dog!
Old 03-16-2009, 06:11 AM
Bob In Ct's Avatar
Ethanol has far fewer calories (less heat energy) in it per gallon than does gasoline. It's the sort of solution to a problem that scientists would discard but lawyers and business persons would latch onto.
Most of our elected officials in Washington believe that if you leave the refrigerator door open, the kitchen will eventually get cool, when in fact it will get warmer.
and yes, I am a chemist
Old 03-16-2009, 07:25 AM
Wayne Maybury's Avatar
Canadian Gashole
One thing not mentioned is the fact that many of the major fuel ethanol producers are having financial problems. Verasun was one of the biggest and they have gone bankrupt. The share value of many of the remaining fuel alcohol producers is in the tank.
Another thing never mentioned by politicians is the fact that fuel ethanol is energy neutral, at best. That means that the best BTU output that can be obtained is equal to the BTUs required to produce the ethanol. In addition, a car gets about 30 to 35% worse mileage on ethanol than it does on gasoline.
Wayne
Old 03-16-2009, 07:52 AM
427 S/O's Avatar
........ethanol is energy neutral
High five Wayne, the oblivious (washington) still don't grasp that fact.
Perry
Old 03-16-2009, 07:53 AM
Ron61's Avatar
Post
Wayne,
With the corrosion problems from stronger mixes of Ethanol and all the loss of power and mile age, could you expect anything except for them to keep wanting more of it and yet hold the companies that they force to make it liable for any damages it causes. I am not a chemist but from all I have managed to find doing some, not a lot of research on this, it is not the fuel of tomorrow that is going to replace gas and oil like some people would try to make everyone believe. Same for electric cars. I believe that our technology has just about reached its limits on batteries and 40 mile ranges on flat land at 35 MPH are not going to help much. Then there would be all of the electricity needed to charge these flops and they won't allow more power plants to be built. Does this not sound like the best minds in our Govt. at work?
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 03-16-2009, 07:58 AM
Banned
Where's this guy when you need him? Mr. Fusions for all!
As for the whole ethanol debacle, Doc Brown had it right...."Great Scott!"
Old 03-16-2009, 08:55 AM
Cobra Make, Engine: KMP-216S Kirkham Street '66 428 PI
Keep in mind these are the same people who want to run health care.
Health care that will be delivered with the efficiency of the Post Office and the compassion of the IRS.
Old 03-16-2009, 10:59 AM
Canadian Gashole
Ron and others
I have worked in the industrial ethanol industry since 1975 so I have lots of information. I have never been involved in fuel ethanol but that industry has a direct effect on our industry so I watch it very closely.
Fuel ethanol did make sense for one reason a few years ago and that was to quickly get rid of MTBE in US gasoline. MTBE was making it's way into the ground water and no one knew what long term health effects could result. Ethanol was the only quick and economically feasible way of eliminating a potentially very dangerous problem.
Having said that, fuel alcohol produced from corn does not reduce America's dependence on foreign oil nor does it really do anything good for the environment. The big deal these days is ethanol from cellulose. I can tell you that this is probably a very good long term solution but it is nothing new even though it is just now showing up in the papers and on the news. Ethanol from cellulose has been around for a very long time but a significant technical break through is required to make the production economically feasible even when oil is over $100 per barrel.
Now for the problems with ethanol. Let me give you a personal example. I have a dingy with a bullet proof 8HP Mercury 2 stroke on it. I have never touched this engine in the 10 years that I have owned it, that is up until last year when I accidentially filled the tank with gasoline containing ethanol. I then pulled the carb off 3 times, cleaned the fuel filter several more time, emptied the gas tank and refilled it, changed the gas tank and the gas line. It appears that the ethanol ate the gas line which then plugged the fuel filter and contaminated the carb. Since I wasn't aware of what was going on, I kept removing, cleaning, etc only to discover more crap the next day. When I figured out it was ethanol that caused the problem, I pulled everything apart at the same time and I also bought a new gas tank because the alcohol had also eaten the pickup hose in the tank.
Wayne
Old 03-16-2009, 12:39 PM
rattlesnakepete's Avatar
Cobra Make, Engine: Lonestar 427 Comp. 351W
Hope.........
Change......
Way to go Roscoe
Old 03-16-2009, 02:54 PM
MaSnaka's Avatar
Was it Nancy Pelosi who said "I don't see any problem in raising the ethenol levels in gasoline to 20%"? Seems to me that it's just a number to her and the reality of what it means to us is not even a consideration of hers. Boooo!
Just my unsolicited opinion.
Old 03-16-2009, 04:34 PM
lovehamr's Avatar
Stolen Avitar
She doesn't see alot!
Old 03-16-2009, 06:17 PM
1ntCobra's Avatar
Abnormal CC Member
I agree that ethanol is a joke, however I read some where (perhaps Road & Track) that scientists are working on the next generation of bio-fuels where they are engineering bacteria(?) that will digest biological matter into a fuel compatible with gasoline that will not require vehicle modifications like ethanol does.
Ron, you mentioned something about reaching the limits of battery technology, but I remember reading something else where nano-technology had the potential of increasing battery capacity greatly.
So perhaps there still is hope for bio-fuels and electric cars...
Old 03-16-2009, 06:58 PM
jmimac351's Avatar
Cobra Make, Engine: Building 289 Lemans / FFR mkIV chassis w/ Bruce Chervenak
Researching alternative fuels and batteries is fine but manipulating our current energy market with no viable alternative in place is a malicious attack on our way of life. Such is liberalism.
Pics---> www.jmimac351.smugmug.com
Chief Instructor: www.ChinTrackDays.com
Old 03-17-2009, 04:38 AM
joyridin''s Avatar
The problem really isn't ethanol. The problem seems to be our politicians accepting huge sums of money from the Agri-business community to make corn ethanol a staple of our society. In the meantime, Brazil has been making ethanol for years out of sugarcane with great success. It has a much higher BTU ratio than corn and you get 3 times more product per acre than corn. Unfortunately, our government imposes an import tax of 54 cents/gallon on it making it cost prohibitive to import.
We are now seeing the end results of massive campaign contributions to those in charge. Again, the little guy gets screwed.
Old 04-18-2009, 06:42 AM
Cobra Make, Engine: Several
Default A few salient and timely facts & conclusions
APRIL 18, 2009
http://online.wsj.com/article/SB124000832377530477.html
The Ethanol Bubble Pops in Iowa
More evidence the fuel makes little economic sense.
By MAX SCHULZ
Dyersville, Iowa
In September, ethanol giant VeraSun Energy opened a refinery on the outskirts of this eastern Iowa community. Among the largest biofuels facilities in the country, the Dyersville plant could process 39 million bushels of corn and produce 110 million gallons of ethanol annually. VeraSun boasted the plant could run 24 hours a day, seven days a week to meet the demand for home-grown energy.
But the only thing happening 24-7 at the Dyersville plant these days is nothing at all. Its doors are shut and corn deliveries are turned away. Touring the facility recently, I saw dozens of rail cars sitting idle. They've been there through the long, bleak winter. Two months after Dyersville opened, VeraSun filed for bankruptcy, closing many of its 14 plants and laying off hundreds of employees. VeraSun lost $476 million in the third quarter last year.
A town of 4,000, Dyersville is best known as the location of the 1989 film "Field of Dreams." In the film, a voice urges Kevin Costner to create a baseball diamond in a cornfield and the ghosts of baseball past emerge from the ether to play ball. Audiences suspended disbelief as they were charmed by a story that blurred the lines between fantasy and reality.
That's pretty much the story of ethanol. Consumers were asked to suspend disbelief as policy makers blurred the lines between economic reality and a business model built on fantasies of a better environment and energy independence through ethanol. Notwithstanding federal subsidies and mandates that force-feed the biofuel to the driving public, ethanol is proving to be a bust.
In the fourth quarter of 2008, Aventine Renewable Energy, a large ethanol producer, lost $37 million despite selling a company record 278 million gallons of the biofuel. Last week it filed for bankruptcy. California's Pacific Ethanol lost $146 million last year and has defaulted on $250 million in loans. It recently told regulators that it will likely run out of cash by April 30.
How could this be? The federal government gives ethanol producers a generous 51-cent-a-gallon tax credit and mandates that a massive amount of their fuel be blended into the nation's gasoline supplies. And those mandates increase every year. This year the mandate is 11 billion gallons and is on its way to 36 billion gallons in 2022.
To meet this political demand, VeraSun, Pacific Ethanol, Aventine Renewable Energy and others rushed to build ethanol mills. The industry produced just four billion gallons of ethanol in 2005, so it had to add a lot of capacity in a short period of time.
Three years ago, ethanol producers made $2.30 per gallon. But with the global economic slowdown, along with a glut of ethanol on the market, by the end of 2008 ethanol producers were making a mere 25 cents per gallon. That drop forced Dyersville and other facilities to be shuttered. The industry cut more than 20% of its capacity in a few months last year.
What's more, as ethanol producers sucked in a vast amount of corn, prices of milk, eggs and other foods soared. The price of corn shot up, as did the price of products from animals -- chickens and cows -- that eat feed corn.
Texas Gov. Rick Perry reacted by standing with the cattlemen in his state to ask the Environmental Protection Agency last year to suspend part of the ethanol mandates (which it has the power to do under the 2007 energy bill).
The EPA turned him down flat.
The Consumer Price Index later revealed that retail food prices in 2008 were up 10% over 2006. In Mexico, rising prices led to riots over the cost of tortillas in 2007. The United Nations Food and Agricultural Organization and other international organizations issued reports last year criticizing biofuels for a spike in food prices.
Ethanol is also bad for the environment. Science magazine published an article last year by Timothy Searchinger of Princeton University, among others, that concluded that biofuels cause deforestation, which speeds climate change. The National Oceanographic and Atmospheric Administration noted in July 2007 that the ethanol boom rapidly increased the amount of fertilizer polluting the Mississippi River. And this week, University of Minnesota researchers Yi-Wen Chiu, Sangwon Suh and Brian Walseth released a study showing that in California -- a state with a water shortage -- it can take more than 1,000 gallons of water to make one gallon of ethanol. They warned that "energy security is being secured at the expense of water security."
For all the pain ethanol has caused, it displaced a mere 3% of our oil usage last year. Even if we plowed under all other crops and dedicated the country's 300 million acres of cropland to ethanol, James Jordan and James Powell of the Polytechnic University of New York estimate we would displace just 15% of our oil demand with biofuels.
But President Barack Obama, an ethanol fan, is leaving current policy in place and has set $6 billion aside in his stimulus package for federal loan guarantees for companies developing innovative energy technologies, including biofuels. It's part of his push to create "green jobs." Archer Daniels Midland and oil refiner Valero are already scavenging the husks of shuttered ethanol plants, looking for facilities on the cheap. One such facility may be the plant in Dyersville, which is for sale. Before we're through, we'll likely see another ethanol bubble.
Mr. Schulz is a senior fellow at the Manhattan Institute.
Reader comments from Lucianne.com
This should be a warning as a pre-cursor to the windfarm boondoggle we're about to embark on.You can't create a phony market for something no matter how much money you spend on it.Building windmills is the easy part. Wiring them into a grid that could produce enough power for the country is quite another and massively expensive.The liberals don't even want to use nuclear for a supplement. Something that even Europe does.
There have been and currently are, bigger scams around, but biofuels is one of the biggest. It takes food from the mouths of the hungry to make a product that decreases the efficiency of the engine in your car. It required auto makers to spend R&D money on engines that can use this crap. And once again, a few prosper while many do not.
Except that ethanol plants are not "refineries" (where do these reporters learn these things?), a good article. Anybody but a dunce could see this happening.
Years ago, perhaps the greatest thinker since Leonardo, Buckminster Fuller stated we should look at nature's system to understand the directions to take: Nature does the most with the least.
Nature is efficient, very much so.
Therefore, when you spend a dime to produce something that sells for a nickel...whoops!
Letting government underwrite, subsidize, bolster--use whatever cute wording that comes to mind (think mass transit), a loser is just that, a loser!
But if I can pull the wool over your eyes, keep you focused on my left hand while my right goes into your wallet...
When the government wants to do something in the economy the free market is not doing beware! The question should be: if it makes sense why wasn't it being done before, pay no attention to politician's explanations not based on solid facts. The Ethanol boondoggle will cost Americans trillions of dollars. Obama has some more schemes waiting that cost more and makes even less economic sense.
Remember last summer's high gas prices? The prices were high but there was supply.
Now remember jimmah carter's administration when prices were high plus there were shortages? The long gas lines, fist fights over the precious juice and even/odd day rationing
Why do I have a bad feeling about this?
If this idiot of a president isn't going to stop his insane march to his socialist utopia more than an ethanol bubble will burst this summer.
But according to Keith and Janeane I'm just a racist right wing extremeist radical. I'm actually just a member of the vast right wing conspiracy.
I'd love this if I were certain it wasn't deliberate on the part of the Leftist greeniewhackos:
"Force-feeding" is right, and is the signature word for this entire Administration. Everyone in the country is or will be force-fed something they don't want. The purpose is to hijack our freedoms and place them under a one-man rule. I'm not sure the man is Obama; it's probably whomever is pulling his strings.
Still, we are being forced to pay higher and higher taxes, often hidden, to subsidize scientific, energy and climatatic hoaxes. We're being told that we must work until the middle of every year to pay the government for all of its taxes on OUR paychecks.
What is wrong with this picture?
Reply 10 - Posted by: Aggie57, 4/18/2009 8:03:50 AM (No. 5447011)
Max...I spent 38 years with Exxon (Humble Oil and Refining), and I know refineries...this is no refinery.
This is another boondoggle.
All these simple solutions to the world's problems right under the noses of we simpletons. We simply needed obama to show us the way!! /S
Recognize it people! Your "gut" already knew this anyways...
PS: This 'good news' should translate very soon into cheaper T-bone steaks, KFC chicken, porkchops and barbecue, and Frosted Flakes not to mention cake, pie, bread, and any other agricultural product that was being bastardized by the GreenScam Industry....
The 'wind farm' nonsense is just as bad, more inefficient and a greater polluter of the environment than the coal plants. Imagine your view of the Grand Tetons obscured by the sight of thousands of wind mills. It is happening. They take up more space and cover over valuable farm and ranch land. Of course, us rubes out here in fly over country don't count. Just keep our grocery shelves full and we won't notice.
And Congress is doing, uh, WHAT about this? Studied ignorance.
"A free people ought not only to be armed and disciplined but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government."
George Washington
Old 04-18-2009, 06:59 AM
jmimac351's Avatar
Everyone in America needs to read this article. Another example of the power and intentions of the EPA...
Old 04-18-2009, 11:21 AM
Cobra Make, Engine: Superformance #1374 with 392 RDI Stroker
Noticed a problem on my Tri-toon boat running a 225 HP Suzuki. The new ethanol really eats the old black rubber fuel lines. Couldn't figure out why I had to replace them every other year. Full of cracks and dried up. My boat guy says they now only sell a grey type fuel line that resists alcohol and it should last a long time. Like Wayne said, I have to change out filters more often.
Mark
Old 05-05-2010, 07:54 AM
Default Ethanol damage as predicted, maybe worse
http://www.washingtonexaminer.com/op...-92858949.html
Going to 15%, cat converters may overheat under current operating specs.
Even hot enough to affect cylinder temps, according to article.
Old subject, old thread, old poster; proving Tom Kirkham was correct.
George Washington
Old 05-05-2010, 05:37 PM
WardL's Avatar
There are laws already in place (Renewable Fuel Standards Two) that will force ethanol in gasoline to increase to over 20%. The amount of corn produced ethanol doesn't increase much from today, but cellulose ethanol is required going forward. When our government is broke, they are paying a $0.45/gallon tax credit on gasoline blended into gasoline! Tier 2 autos (produced since about 2003) can handle the higher levels of ethanol in gasoline. Pre-2003 (or so) can't handle it. The earlier catalytic converters get trashed for one thing. The higher octane of the ethanol (about 115) is nice and the autos can take advantage of the higher octane fuel.
The only hope is to vote out the current congress. But not much chance the new guy will be able to do anything either....
