| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
06-10-2009, 04:40 PM
SC
One less Cobra in Tampa Bay area
06-10-2009, 04:50 PM
wa
That's a shame.
John Hall
06-10-2009, 05:20 PM
Banned
CA
Link assist...Ouch! Sure hope the owner got out okay and has insurance to cover/rebuild.
06-10-2009, 05:56 PM
FL
Cobra Make, Engine: Kirkham #570 w Shelby FE
One real bad thing about fiberglass, it burns.
06-10-2009, 06:13 PM
Appears to be West Virginia tags....
06-10-2009, 07:08 PM
OK
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
Man, that picture turns my stomach!
Hopefully no one was hurt.
Juggernaut
06-10-2009, 07:36 PM
NJ
Cobra Make, Engine: B & B
That is one of my worst nightmares. Assuming the driver got out safely, he must have felt so helpless!
I think some of the fire spots can be buffed out?
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
06-10-2009, 09:12 PM
FL
Good call : http://www.15q.net/curr.html
They are W. Virgina tags.
06-10-2009, 09:26 PM
Ca
Fuel Fire. Coolant on the ground. The worst sound to hear... WHoomp, followed by instant heavy smoke. Maybe an under hood Halon extinguisher might have helped.
Rick
06-10-2009, 09:29 PM
tx
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
That's exactly why I have a fuel cutoff switch and a fire extinguisher.
" It ain't no big deal"
06-11-2009, 05:54 AM
OK
Yep, I have the fuel cut off switch on my dash right next to my battery cut off. You never know when something like that can happen. I saw a late model Nissan Pickup on the freeway here that was burning in a similar way. Scarry and sad.
Clois
"Let's roll"
"Be part of Something Good
06-11-2009, 06:18 AM
This thread could become the poster-child for mechanical fuel pumps.
06-11-2009, 07:15 AM
FL
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Does anyone know what started the fire?
06-11-2009, 08:57 AM
Ca
Seeing this should encourage everyone to take a moment to check their entire fuel system, and consider installing a fire extinguisher.
Rick
06-11-2009, 10:36 AM
GA
Cobra Make, Engine: 65 Factory Five MKIII Cobra
West Virginia tags, but I can assure you there are no palm trees in West Virginia. How bad would it suck to have this happen and also be on vacation with your car?
06-11-2009, 10:52 AM
AL
Yep, I have the fuel cut off switch on my dash right next to my battery cut off. You never know when something like that can happen. Clois
I too prefer an electric fuel pump, so when I designed my dash, I went back to something I liked in the military aircraft I used to fly. Of the dozens of switches in the cockpit, a few were guarded by red covers that served two purposes. First, they drew attention to the critical switches that might need attention during an emergency. Second, they were installed so that closing the covers moved the switches to the default position you'd want during an emergency. So, in addtion to the big red battery disconnect switch on my dash, I have red covers that will shut off the switches for my ignition and fuel pump when closed.
Tommy
Previously owned EM Cobra
06-11-2009, 11:38 AM
Cobra Make, Engine: currently Cobra-less
almost looks like this one:
http://www.clubcobra.com/classifieds...duct=687&cat=2
naah, different taillights
when in doubt, floor it
06-11-2009, 11:51 AM
UT
Cobra Make, Engine: FFR with a 345-horse 302 Crate Engine
I can't run a mechanical pump with my setup, that's why I have a manual switch under my dash to kill the electric pump as well as an inertia switch wired in the circuit so that if the car was ever hit really hard that the switch would (hopefully) open as designed and kill fuel flow to the carb.
Jim Doak
FFR 2117
06-11-2009, 12:16 PM
OK
Cobra Make, Engine: Fords
new checklist:
1) oil
2) coolant
3) fuel lines & fittings
Z.
'65 K code Mustang
'66 Galaxie 500
06-11-2009, 12:21 PM
VA
Originally Posted by 86Sebring
Is that a small gas leak I see next to the carb in the engine picture ??!!
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
