| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
06-11-2009, 08:01 AM
Club Cobra Member
NJ
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Helmet face shield fogging up
What do you use to keep the face shield on a full face helmet from fogging up? I read some where they used dish soap?
 Snakebit
06-11-2009, 08:20 AM
Cobra Make, Engine: CSX2321
Just do what's done with dive masks, you spit on it.
06-11-2009, 08:24 AM
Ca
Stop smoking with the face shield down. Duh!
Jim
06-11-2009, 08:55 AM
Cobra Make, Engine: SPF#0760
Stop breathing for a few mins...
SPFWiringDiagrams@Comcast.net
06-11-2009, 08:58 AM
CA
Try replacing your visor with a "fog free" shield if available. They also sell a spray that will reduce fogging. The other thing is try to find a visor that is vented.
Last option....try an open faced helmet.
Doug
06-11-2009, 09:22 AM
Mo.
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Try your local scuba diving shop. Most will have an anti-fog spray used for dive masks that will work just fine on your face shield.
The reason divers spit in their mask is saliva contains a small amount of silica, which when smeared on the interior lens of the mask helps to defeat the fogging process.
You can also try rubbing in a light film of silicone from a can of silicone spray, just a tiny amount on a rag and rub down the inside of your shield.
06-11-2009, 10:11 AM
Super Moderator
CA
RainX Anti-Fog...easier to find.
Jamo
06-11-2009, 05:45 PM
NY
Lots of good recommendations above, but if it still fogs up, try this quick trick that one of the instructors told me about at Mid Ohio.
Get a small piece of soft foam insulation about 1/4" thick, 1'4" wide, and about 1 1/2" long with the sticky backing on one side.
Place it in the middle of the lower opening for the face shield so that it goes from the outside of the helmet across the opening to slightly inside the helmet.
You are then able to open the face shield if if it starts fogging up, close it back to an "almost" closed position where it will remain, and if you push the face shield a bit harder it will go back to the "locked" closed position.
Dave
06-11-2009, 09:44 PM
Ca
Cobra Make, Engine: SPF #1436 514
Motorcycle shop will have the anti-fog spray. I used it all the time. Then I started using Warps plexy glass cleaner from Orchard Supply. My dirt bike goggles never fog up!!
Scott
06-12-2009, 01:58 AM
Super Moderator
CA
bobcowan...don't know "which" particular shields you've experienced problems with, but I've never had a problem with RainX Anti Fog nor has anyone else I know that uses it...passed the bottle at more than a few meets over the years. Also know a few fire department folks who use it as well.
Sure it was the Anti Fog product and not regular RainX?
Jamo
06-12-2009, 06:55 AM
NY
Cobra Make, Engine: ERA 758 KC Pond 482
From many wet races in an open cockpit car- Rain-x anti fog helps a lot but isn't fool proof; crack the visor open slightly. Also, I used to put a small piece of weatherstrip foam along the bottom which helps regulate how much air gets in when the visor is cracked open.
06-12-2009, 01:28 PM
Club Cobra Member
NJ
Did some research on the internet. The motorcycle guys recommend "Cat Crap" Yes, that's what its called. It's a green gel that turns clear when applied with your finger and you buff it with a soft towel. Sold at sporting good stores. I have not tried it yet, nor did they comment on what your finger smells like after applying it.
 Snakebit
06-21-2009, 10:44 PM
CO
I use the RainX no-fog solution on my windshiel. it works pretty good, since I don't have a defroster.
I tried it on my Nolan helmet shield. After about a week it fogged the sirface, and I couldn't polish it off. I had to replace it. That's the no fog, not the regular RainX product.
I also tried regular RainX on a Bell shield quite a few years ago. That fogged the shield really quick.
06-21-2009, 11:06 PM
Super Moderator
CA
Not sure if some personal experiences are enough to tell someone NOT to use a widely-used product...maybe a warning to try a small portion of the face shield might have been a more proportionate response.
Again, I've never had a problem, nor have others at the track with me, on a variety of mfg's shields...Bell included for me personally. I tend to crack the shield open a bit like xracerbob says...mostly for comfort...so maybe that has helped.
In any event...
Jamo
