Old 08-01-2009, 05:13 PM
Cobra Make, Engine: Contemporary CCX33344 with original bore 427 SO.
Default Wire hot to the touch
Guys,
I was working under the dash and touched the 10 Ga yellow wire that runs from the alternator to the ammeter and it was too hot to touch. Smells too.
Does this mean the ammeter is going? I'm afraid to drive it like this...
Can I test the resistance of the ammeter?
Old 08-01-2009, 05:28 PM
Does it only do this after running or with the key off and not has been running? If it is only like this after running then you need to check it out at your leisure (don't drive it of course). If it is just sitting there and has not been driven but the wire is hot to the touch, unhook your battery and get someone to look at it.
I would not be sure but it sounds to me like the alternator is putting out too much power to the gauge. Bad alternator maybe? As you say the wire is coming from your alternator then my guess is that you have an internal regulator and that might be bad. I am no professional by any means. I am sure someone else here can help better than I.
Terry
Old 08-01-2009, 05:45 PM
That won't tell you what you want to know. I'm going to assume that your ammeter is not reading +100 the whole time you're running. If you were to put an ohm meter across your ammeter the resistance is going to be zero even if it is acting "like a skinny little wire" when really it should be "a reasonably fat wire." If you were to test it, you would need to put a measured load (watts) in a circuit along with the ammeter and your measured voltage. That's a PITA. What I would do is check the connections on your wire and, assuming you don't find anything loose or wiggly, put a ten gauge jumper wire securely across the terminals of your ammeter -- that will effectively negate your ammeter. If your wire heating problems then disappear, replace your ammeter. Make sense?
Old 08-01-2009, 06:22 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
A loose connection can cause heating in the wire too, so check both ends of the wire and the crimps. But as was mentioned, your voltage regulator may be the problem. Easy enough to test, just get you volt meter out and start the car, and check the output. Should be 13.8 to 14.2 volts...How's the fluid level on your battery. Many times, overcharging with boil out the battery liquid, and you get an acid smell too... Correct this before driving or you could be rewiring melted wires all over the car...
SPFWiringDiagrams@Comcast.net
Old 08-01-2009, 06:47 PM
vettestr's Avatar
What is the gauge showing the charge or discharge rate is? I ask out of curiosity as the wire and gauge should not be hot if 10 or 60 amps are displayed but a 60 amp discharge may be a clue to a major discharge or load downstream.
With the key on but engine not running the gauge display should be about zero. Check to see if wire heats up with key in on position but not running. Note display and if anything is running or not running that should be. Removing a fuse from items like fuel pump should stop remove discharge showing on the gauge.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 08-01-2009, 07:48 PM
PANAVIA's Avatar
Could be just tooo muuuch stuff -- Fans and lights can add a lot of load, not to mention MSD boxes. --
Old 08-02-2009, 03:21 PM
Thanks for the ideas guys
I disconnected the battery until I can check it out.
Old 08-02-2009, 04:11 PM
Default You have a private e-mail
Fastz06 you have a message
Old 08-03-2009, 10:43 AM
Joe Wicked's Avatar
A hot wire has too much current going through it for it's size. This can be caused by having too much powered by the system (overloading), or by a bad component loading to ground. Bypassing the Amp gauge will tell you if it is the gauge, but I would think that it would be something else down the line. I had a similar problem on a 460. Turned out the Starter Solenoid was getting stuck. This created a huge load on the system and was burning up the wire. I shut off the truck and smelled something burning opened the hood and found the same wire you have getting hot on fire.
If you have a good multimeter, you can disconnect the Ammeter and use the Ammeter function of the multimeter to see if it is reading correctly. Be careful though as if it is from overloading you can damage the meter if you don't have the settings right.
Why do they call it "Common Sense" when it is so rare?
Old 08-03-2009, 10:50 AM
CHANMADD's Avatar
This is the reason that manufacturers stopped using an ammeter and went to using a Volt Meter. I had a car catch on fire once because of an ammeter.
Old 08-03-2009, 04:58 PM
Pick up a current indicator off ebay or NAPA. These lay across the wire and show you how much current the alt. is generating (load matching). I have a set of these from Snap-on, don't waste money on the digital ones that may or may not work three years from now when you need to check it again. My Snap-on's have always worked when I needed them over the past 20yrs unlike the 6 DVMs I've been through. (My Simpson 260M still works like a charm as well)
How big is your alternator? 10ga is not big enough for anything above 60A.
Although the voltmeter is more critical with today's electronic stuff like ignitions it doesn't really replace the amp meter. (ideally you'd want both in my view)
Old 08-04-2009, 11:18 AM
Joe Wicked's Avatar
Very good point that I did not mention. Goes to the overloading category, but you don't always have to have too much pulling current. You could be producing too much for the wire.
Old 08-04-2009, 02:54 PM
Cobra Make, Engine: KMP532, KC427FE, TWM
Your wire is to small:
http://www.cerrowire.com/default.aspx?id=46
http://www.powerstream.com/Wire_Size.htm
I run a #8 from my alternator, although #6 would run cooler.
Cobra: A weapon of gas destruction
www.KobraBytes.com
Old 08-04-2009, 03:11 PM
But those numbers are for steady current. My amp gauge, like most of our cars, shows its highest current right after starting the car while it's charging the battery -- and even then it's under 20 amps and only for a relatively short while. If your amp gauge is reading consistently over 5 amps all the time then you have a problem. The amperage running through the charging wire is usually very low almost all the time.
Afterthought -- The hghest amperage might be hit though when the fans are still running after the engine has been turned off.
Last edited by patrickt; 08-04-2009 at 03:15 PM.. Reason: Came up with the afterthought...
Old 08-04-2009, 03:29 PM
Trust me, you are drawing too much power, otherwise the wire would be cooler. When the car is running your alternator is supplying the power. Fan, fuel pump, ignition, lights, etc. I've been through this...
Do you know for certain how your amp gauge is wired? It sounds like it is only wired between the battery and alternator, NOT showing the running load.
If you have a good schematic, send it to me.
len
www.KobraBytes.com
Old 08-04-2009, 03:41 PM
len
He definitely has a problem on that wire, and it could be a faulty amp guage, or maybe even a partially grounded amp gauge, or a partial short on the wire on the alternator side of the circuit so the current is not running through the ammeter.
Last edited by patrickt; 08-04-2009 at 06:03 PM.. Reason: Deleted faulty reference...
Old 08-04-2009, 05:00 PM
Love people who can produce a schematic!
The amp meter ONLY measures charging current in this schematic, and NOT the output of the alternator to the accessories. It will however measure the draw from the battery to the accessories when the car is NOT running.
Disconnect the R and N wires from your amp meter and use an ohm meter to see if you somehow have a grounded meter. (Gnd to + and Gnd to -)
Use an amp meter to check your accessory draw. Do it one at a time. You'll probably blow the fuse in your amp meter when you check the fans unless your meter is good for more than 20 amps. With the engine not running disconnect the positive lead on the battery and put the meter between the battery terminal and the cable. (Ignition switch on run)
Before you turn on the ignition switch is there any draw?
If you use an MSD multiply your reading by 6. THe AL's draw 1 amp per k of RPM
How large is wire N? Amp gauge to battery?
Does O (alternator wire have a fusable link in the case of a short?
www.KobraBytes.com
Old 08-04-2009, 05:06 PM
Kobrabytes -- there's some confusion here. He doesn't have an ERA, so that schematic doesn't apply (that's my schematic, and remember I don't have a problem, well not an electrical one that is.)
Old 08-04-2009, 07:09 PM
Lol...
Trace it out... Take two aspirin, email me in the morning...
www.KobraBytes.com
Old 08-04-2009, 07:16 PM
Lol...
I find this thread interesting, and I hope Fastz06 gives us an update, because 30+ years ago I had an amp gauge go bad and it heated up the wire and eventually smoked it. Now granted I've owned a lot of cars with amp gauges, and that has only happened once. I can't remember whether the amp gauge gave any warning (like showing a goofy reading or something) before it finally burned up the wire.
