Old 08-31-2009, 01:54 PM
priobe's Avatar
Default Body Bushing
As I am preparing to gather everything for when I body comes back from paint, what have you used for body bushing between body and frame?
Old 08-31-2009, 08:04 PM
I just bolted my body to the frame and the reason was if i put something in there it will allow the body to move ever so slightly that it would eventually wear out and fall out and thats not good so i just bolted it to the frame and have had no problems at all with wear between the frame and body.
Old 09-01-2009, 05:21 AM
mdross1's Avatar
After working my frame over for fuel, brake lines,and under car exhaust,it became very clear just how heavy and stiff this piece is.So I drilled and tapped all the mount holes and bolted the body directly on the frame.Also considering the bumper mounts,radiator shrouding,brake lines,cowl support,door hinge bracing roll bar,etc no need for the body to be moving around.
