Old 09-25-2009, 05:31 PM
cobred's Avatar
Cobra Make, Engine: ERA #698 428 Toploader
Default Roll bar harness mount wanted
I am looking for the shoulder harness mount for a 1.5 inch roll bar. Also the 2 inch shoulder harness in black that clips onto the mount.
Old 09-25-2009, 06:07 PM
RonNichols's Avatar
Cobra Make, Engine: SPF398/460ci/ 144hp of backfiring fury
I bought mine at Finishline. You will need 1/8" rubber sheet as a spacer to hold it on snug. Don't overtighten as the cast iron will break.
R
Old 09-25-2009, 06:37 PM
mickmate's Avatar
That would scare me if the thing would break from being tightened. Not a good sign for a harness attachment point. I have made some to customers specs from the next size up DOM tube. If you need some help with it let me know.
mickmate
http://www.actoncustom.com/
Old 09-25-2009, 08:43 PM
legenmetals's Avatar
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
I would recomend five point harness if this is new installation.In the event of a sudden stop you will likely slide under the lap belt causing internal injury.If you google five point racing harness you will find plenty of good reading on this. I welded a mount for the submarine belt on to my chassis and had my upholsterer cut a slit in the seat and sew welting around the slit.The submarine belt has to be at the proper angle in relation from the mounting point to your chest,web sites will explain this.Finishline was my source for the roll bar mount. A picture of my installation was posted on the roll bar thread on Monday.
