Go Back   Club Cobra > General Discussion > All Racing Talk
Old 06-03-2002, 05:01 AM
Clois Harlan's Avatar
Default Oil Pressure at speed drops
I was racing this weekend at Omaha's new road course (excellent course) at a Ford/Cobra event when I was watching my oil pressure gauge (amoung everything else), after about 5 laps my oil pressure was falling from about 45 psi DOWN to about 20 psi. I am running Castrol 20W50. The outside temp was about 86 degrees and the track temp was close to 100 degrees. I am running a High Volume oil pump from Melling with a functional oil cooler. Is this normal or should I take some other action to maintain higher oil pressure?
Thanks,
Clois Harlan
PS-I have another road event here in Tulsa in less than TWO WEEKS (sure don't want to break in front of the home crowd).
"Let's roll"
"Be part of Something Good
Old 06-03-2002, 05:05 AM
Frank Coppola's Avatar
What oil pan are you using? Where on the track were you losing pressure?
Frank Coppola
___________________________________
"Gunga Galunga... gunga, gunga-galunga."
Old 06-03-2002, 05:29 AM
I am using the Tony Branda 61/2 Quart Alum oil pan. I believe I was just coming out of a turn when I noticed. I also checked again as I was running my cool down lap and when I exited. My oil pressure seems to like to stay around 38 or 40 when I am warmed up.
"Let's roll"
Old 06-03-2002, 05:46 AM
From my limited knowledge it sounds like the oil pan. Centrifugal force cause oil to temporarily move away from the pump. You could either replace you pan with a Canton "race" pan or add a oil accumulator. (Check out "Accusump" or Moroso)
I haven't heard too many great things about the performance of the low profile "cobra" pans. My engine builder promptly removed mine and replaced it with a Canton "T" sump 7 quart pan. It rides ALOT lower than the original, but I haven't hit anything with it, yet.
Frank Coppola
Old 06-03-2002, 06:13 AM
Thanks Frank,
My oil pan is currently setting only 4 1/2" off the ground. I also checked into the Canton Pan but was affraid of the height. I also called a guy in California who builds custom racing pans named Armando, I believe he charges about the same as Canton and they are about the same depth as minie. Still trying to decide what to do.
Something else I noticed about my cast aluminum pan was that it appears to be sweating oil through its pours. Have you ever heard of this?
"Let's roll"
