Go Back   Club Cobra > General Discussion > All Racing Talk
Old 05-01-2007, 05:26 PM
Cobra Make, Engine: SPF 239
With similar piston area, and caliper mass, performance will be identical. The only true advantage of a 6 piston vs. 4 piston is control of pad taper. The leading edge pistons are smaller to reduce the clamping force so that the pads will wear evenly. On race cars with complete pad and rotor wear over the course of an event, this is important.
The key is to use the smallest / lightest caliper and rotor package, that can absorb the energy (heat) your car produces, then shed it prior to the next input cycle. The system must have sufficient mass to absorb the heat while keeping the pads from exceeding the maximum temp (fade) or causing the fluid to boil (fade).
6, 8, 10 piston calipers look great (to me) but they offer very little performance advantage over a properly sized, differential bore, 4 piston unit unless you are in a 10/10ths application.
Wilwood vs. AP vs. Brembo……
Once upon a time I was a manager @ Wilwood. During my time there, I was afforded the opportunity too play with every bodies toys. I can say without question that the high end Brembo and AP offerings are fantastic parts. Beautifully machined, and assembled. They perform as a very expensive caliper should, perfectly.
However in blind testing, there is no perceivable difference between them and the Wilwoods.
I am asked on a regular basis “Why are Wilwoods so cheap?”
My response is always: “Your question should be, why are the other guys so expensive?”
Are you getting a great caliper from AP for $900.00? Absolutely. Is it $500.00 better than a Wilwood? Not to me. Its nice to be able to buys pads for $50-$60 a set and replacement rotors for $70.00 -$100.00
Many people perceive value in the higher cost item “its more expensive, it must be better” Also a discussion we had many times @ Wilwood.
Hence the name
D-cel
Jason
P.S.
Still a Wilwood dealer if anyone needs parts
Old 05-02-2007, 06:13 AM
rdorman's Avatar
Renegade Nuns on Wheels
What D-Cel (Jason) said. Although I seem to recall some staggered bore 4 pistons as well. Either way, Wilwood is the best bargain in performance brakes today and their full disclosure of technical data such as the temp vs cf charts on their pads make it, at least for me, my first stop if I am designing a brake system for some one. My oldie but goodie Unique uses an MG front end and the wilwoods don't fit... at least until I was done machining their hubs they didn't. It was worth the time. The difference from the Girlings is nothing short of miraculous.
Jason... did you ever get my brake work sheet? It is in Excel and you can enter all the paramaters (everything from aero CG's and specs down to tire CF) and play with the combinations on paper before you try it in real life. You would probably have fun playing with it. Email me and I will send you a copy. Also, The wilwood kit I modified to fit the MG spindles was a 70 chevy mid size kit as I recall with 10.75 rotors. I want to change those out for the 12.19 so I will be in touch!
OhioCobraClub.com
LondonCobraShow.com
Old 05-02-2007, 03:25 PM
Ant Ant is offline
Default Calipers
Jason, Scott
Thanks for your advice, and I agree a nice 4 pot setup will do a good job, once all the right pad compounds etc is sorted!
I have decided to go to the Wilwood SL6R #120-6385-RS caliper, as it still runs 20mm common pads, and has a narrow outboard body, which after having another measure up the SL6R gives me a bit more badly needed clearance. This problem arose as the Compomotive wheels have less offset on the hub mount than the Trigo which reduced my caliper clearance, Compomotive told me that the wheels were the same..........!?!
For the rear of car I am trying to find some calipers, from a hi-perf road car which have a handbrake incorporated, plus on the rear to keep it simple I have access to rotors/hats all one piece factory eg BMW etc that I can adapt to the rear!
A J. Newton
The 1960's rocked!
Old 05-02-2007, 04:14 PM
Ant,
Wilwood now has a hydo-mech rear caliper as you are describing. They call it the "Combination Parking Brake Caliper"
Here is a link: http://www.wilwood.com/Products/001-...-cpb/index.asp
The only problem I have found with this type of rear caliper is its lack of mass and surface area. In a Hi-perf/track application, you must run a lot of front bias in the system to keep the rears from boiling out the fluid.
This is a common problem on early Vipers. When the owner does a pad-line upgrade (which they desperately need) The rears get hot so fast that they boil the fluid, burn the seals. Then fluid squirts onto the red hot rotor and bursts into flames!!
Cars with good rear weight bias (Cobras &Vipers) benefit from a little more rear caliper. I like 1” bore Dynalites or NDL’s and then use the Combo caliper as the P-brake only.
Jason
Old 05-02-2007, 04:46 PM
Ant Ant is offline
Default Brakes
Jason,
Thats the thing with these cars and they need good rear brakes, also the more calipers on the rotor the less air around it for cooling. With the handbrake I can get dispensation for a hydraulic handbrake while I own the car, which maybe a way around it!
The Dynalites with 1" bores seem to be popular with a lot of race guys here for the rears. I have also seen very good Jap hi-performance 2 pot calipers grafted into setups, and as mentioned one piece ventilated rotors 11" & 12" available in different offsets here for $60-$80, we have guys here that have built some of the fastest race cars in NZ with a very simple rear common setup, but I as you mentioned there is potential for uneven pad wear with less than 2 pot calipers.
A J. Newton
The 1960's rocked!
Old 05-03-2007, 11:30 AM
I have a set of PBR rear calipers, they are a big single piston floating caliper. They come with the E-brake attachment. I would sell them to you if interested.
On boiling fluid, I have boiled 4 or 5 different brands. The castrol SRF is a must, it will not boil.
Scott
Old 05-03-2007, 03:43 PM
Ant Ant is offline
Default Brakes
Scott,
Will keep that in mind, as you can gather I am not sure on how far I want to go with rear calipers, as I normally tend to go overboard, but the $$$ add up!
Castrol SRF, thats a good recommendation, I have always liked Castrol products, and used their brake fluid in the past, but I think that was only Castrol LMA.
A J. Newton
The 1960's rocked!
